    [Solved]How to use interruption processing in m5stack
    Cores
    18.6k
    • T
      tkb koki
      I want to make a simple game.
      When you pressed button of m5stack, how did you move other function?
      There is not other function in roop().I use Arduino1.8.9.
      • m5-docsM
        m5-docs @tkb koki
        @tkb-koki Do you means how to use BUTTON on M5Stack Core?
        If I am right, you can refer to the code blow.
        https://github.com/m5stack/M5Stack/tree/master/examples/Basics
            Created:    2018/9/21 14:06:15
            Author:     sakabin
        #include <M5Stack.h>
        // The setup() function runs once each time the micro-controller starts
          // init lcd, serial, but don't init sd card
          M5.begin(true, false, true);
          M5.Lcd.clear(BLACK);
          M5.Lcd.setTextColor(YELLOW);
          M5.Lcd.setTextSize(2);
          M5.Lcd.setCursor(65, 10);
          M5.Lcd.println("Button example");
          M5.Lcd.setCursor(3, 35);
          M5.Lcd.println("Press button B for 700ms");
          M5.Lcd.println("to clear screen.");
          M5.Lcd.setTextColor(RED);
        // Add the main program code into the continuous loop() function
          M5.update();
          // if you want to use Releasefor("was released for"), use .wasReleasefor(int time) below
          if (M5.BtnA.wasReleased()) {
            M5.Lcd.print('A');
          } else if (M5.BtnB.wasReleased()) {
            M5.Lcd.print('B');
          } else if (M5.BtnC.wasReleased()) {
            M5.Lcd.print('C');
          } else if (M5.BtnB.wasReleasefor(700)) {
            M5.Lcd.setCursor(0, 0);
        © 2019 GitHub, In
        M5Stack documentation URL
        https://docs.m5stack.com
        • T
          tkb koki
          @m5-docs No, i was able to use BUTTON.
          I want to use other function while executing "delay();".
            ajb2k3 @tkb koki
            @tkb-koki What programming system are you using?
            In UIFlow you have a series of loops including loops dedicated to just the three buttons on the front.
            • m5-docsM
              m5-docs @tkb koki
              @tkb-koki multi-Progress?
              • T
                tkb koki @ajb2k3
                @ajb2k3 I am using Arduino IDE.
                • T
                  tkb koki @m5-docs
                  @m5-docs not multi. I want to use interruption processing.
                  • m5-docsM
                    m5-docs @tkb koki
                    Hello @tkb-koki,
                    How about this example code?
                    https://github.com/futureshocked/ESP32-For-Busy-People-1/blob/9ede724a862539ae18aad1500426ceb4415d5052/04-070_Interrupt_with_button_and_led/04-070_Interrupt_with_button_and_led.ino
