Ui Flow 1.3.2 (web) has dropped Stick
Hi
I’ve noticed the new 1.3.2 has no longer support for the grey/white Stick. Is it temporary or shall we kiss goodbye to our little fellas?
Cheers
We are very sorry, stick-UIFlow is stop update
@ipodlux as long as you can remember the limits of the gray, it can still be programmed as an M5Stack.
@heybin this is a bad idea as there are too many out in the wild, you need to keep supporting the stick for another two years minimum!
Indeed, making a device obsolete after months it's not a good practice and won't look good on the 'brand'. 60$ in the bin...
Bump
So what now Stick Gray is end of life ?!
With the StickC and StickV the stick is obsolete however, as I mentioned it can still be programmed in UIFlow
@ajb2k3 yes in old version ... there was any reply from official guys about it ?
@mati said in Ui Flow 1.3.2 (web) has dropped Stick:
The offical answer was that it is obsolete and they don't need to support it.
