    Max 5v current out
    5 Posts 4 Posters 12.6k Views 1 Watching
      klimbot
      I'm looking to make my own hat for my M5StickC and was looking to find the max current out available at 5v. Any ideas?
      Thanks.
      W ajb2k3A 2 Replies Last reply Reply Quote 0
      • W Offline
        wikistik @klimbot
        @klimbot Here are some results of practical testing:
        Using the 5v header pin with the screen set to black and set to minimum brightness, flashing the led to make sure the cpu was still operating: I could draw about 400ma at the load (fluctuated between 388 and 402 using an incandescent light as a load). This was the case on both USB and battery power.
        Using the 5v header pin with the screen displaying some text: the same load drew 500ma but it shut the screen down and the computer did recognize the unit until I replugged it in.
        So let's say under 400ma with the screen "off" and considerably less with it on.
          klimbot
          Awesome, thanks for sharing @wikistik!!
          Will take this in to account when designing my hat.
          • B Offline
            Bese
            Powered by USB:
            5V -> 500mA
            3.3V -> 500mA
            Powered by Vin:
            5V -> 2000mA
            3.3V -> 1200mA
            You need to subtract the M5Stick's own consumption from these values.
            M5Stick is using the AXP192 Power management IC, datasheet:
            http://www.x-powers.com/en.php/Info/support/article_id/29
            M5Stick schematic:
            https://docs.m5stack.com/#/en/core/m5stickc
            @klimbot probably powered his M5stick via USB.
              ajb2k3 @klimbot
              @klimbot said in Max 5v current out:
              Thanks.
              Depending on what kind of hat you are designing, you could design it so that it directly powers you device and supplies power to the stick instead of the stick supply the power.
