    Connecting Env Unit and RFID Unit via Grove Hub on M5StickC
    M5 Stick/StickC
    12
    21.1k
    • W
      ws1088
      Individually connect to the Grove Hub works. But if I put both on the hub, it will gives
      ENV unit maybe not connect
      This is the code from UIFlow:
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import unit
      setScreenColor(0x111111)
      rfid0 = unit.get(unit.RFID, unit.PORTA)
      env1 = unit.get(unit.ENV, unit.PORTA)
      wait(1)
      while True:
        lcd.print((('C: ' + str((env1.temperature)))), 0, 0, 0x3366ff)
        lcd.print((('RFID: ' + str((rfid0.readUid())))), 0, 10, 0x3366ff)
        wait_ms(200)
      Even if I manually switched the order to:
      I still get:
      What am I doing wrong? Thanks in advance!
      • W
        ws1088
        I use the following code to test:
        from m5ui import *
        import i2c_bus
        devices = None
        scan = None
        i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x68)
        devices = []
        while True:
          scan = i2c0.scan()
          if devices != scan:
            lcd.clear()
            lcd.print(str(scan), 0, 0, 0xffffff)
          devices = scan
          wait_ms(2)
        I can see the I2C addresses for the Env unit and RFID unit combinations when I plug them into the Grove Hub. I can plug the Env unit in to see addresses 92 and 118, then add RFID unit to see [40, 92, 118] etc.
        So I am pretty clueless why the following will fail:
        Looks like I need to go to the source code and see what's going on...
        • W
          ws1088
          It looks like Env unit has 2 I2C addresses (92, 118)? But many times 92 will go away in the scan loop. Strange...
            All I can think is that the two sensors are drawing too much power for the bus.
            I have both units and also the hat versions. if I find time over the week end I may have some time to test but I may need a reminder on saturday.
            Double check the address's. The published addresses are in Hex but they are displayed in binary on the screen!
              ajb2k3 @ws1088
              @ws1088 Confirmed, the RFID Unit will not work with the ENV unit and will not work with the ENV hat
              W 2 Replies Last reply Reply Quote 0
              • W
                ws1088 @ajb2k3
                @ajb2k3 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
                Is the reason as you mentioned that there is not enough power? I guess not because you test it on the ENV hat with RFID unit. I noticed a lot of bus error (timeout), maybe it's a software issue? I am using UIFlow, btw. Are you using Arduino IDE and C++?
                  ajb2k3 @ws1088
                  @ws1088 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
                  Nope, only UIFlow as I'm trying to write the book on it.
                  • W
                    ws1088 @ajb2k3
                    Could this be related?
                    http://community.m5stack.com/topic/523/problems-with-the-i2c-grove-interface
                    • W
                      ws1088 @ajb2k3
                      wow, RFID unit will not work with ENV hat even? I though RFID unit is I2C (G32 and G33) and ENV hat is on G26 and G36...
                        ajb2k3 @ws1088
                        I could not get them to work together but then i am not a good programmer.
                          maknis3
                          Fellow users from the past, I encountered the same problem but managed to get it working. The problem lies in the paralell access of the RFID and ENV module. If the access is isolated in a paralell process and saved in to variables, further getting the values by using these variables, you should be able to use the two modules in unison.
                          • robskiR
                            robski @ws1088
                            from m5ui import *
                            import i2c_bus
                            devices = None
                            scan = None
                            devices = []
                            while True:
                              scan = i2c0.scan()
                              if devices != scan:
                                lcd.clear()
                              devices = scan
                              wait_ms(2)
                            are modules working ok on their own and you see issue when both connected?
