    [solved] Getting Microphone to work on M5Stick
    11 Posts 5 Posters 23.5k Views 1 Watching
      spiffmonious
      Im having trouble getting the mic to work on the m5stick (non C). Does anyone have working code that they can post or point to?
        spiffmonious
        I guess I need to break this down: Does the stick even have a microphone?
        if it does, is it pin 34?
        running an i2c scanner show three address: 0x75, 0x68, and 0x0c. I think the 1st two are battery and mpu6050. Who's at 0x0c?
          spiffmonious
          @m5stack, @ajb2k3
          • m5stackM Offline
            Hi , M5Stick have not Microphone , and have not device the address is 0x0c , it maybe just a mistake from I2C scan.
              spiffmonious @m5stack
              @m5stack You need to update your product listing, cause it states its has a mic and I bought one based on that.
              https://m5stack.com/collections/all/products/stick
              • m5stackM Offline
                @spiffmonious OK thanks your review. i will change the Product imformation.
                  ajb2k3 @spiffmonious
                  @spiffmonious The microphone was an optional addon (If i remember correctly).
                  • lukasmaximusL Offline
                    @spiffmonious Sorry if the description was not accurate. The microphone on M5Stick was only available by custom request. There are bare pads on the pcb of the M5Stick to solder a mems microphone on to, such as the SPM1423. If your not keen on opening up your M5Stick and just need to check sound intensity I suggest you could use this grove compatible sound sensor https://www.seeedstudio.com/Grove-Sound-Sensor.html
                      spiffmonious
                      Ive marked this solved since we've answered my question and the erroneous product page has been corrected.
                        spiffmonious @lukasmaximus
                        @lukasmaximus If there are pads for the mic, you folks should go ahead and put one on and sell the m5stick like that. There would be a market for that product and Im sure people would pay a little bit more for the upgraded stick. Sure, a mic can be connected, but that defeats the wearable aspect of the stick. Just a suggestion.
                          hdac
                          What about on the m5stick c
