šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    UIFlow can't download code in m5stick-c recently.
    3 Posts 3 Posters 4.6k Views 1 Watching
    • L Offline
      lsy51739488
      I can only run the code, not download the code. I tried two sticks, both of which are the same,as if they had only appeared in the past few days.Error prompt:Upload code failed,maybe your device is offline check it and retry.
        Thrasher @lsy51739488
        @lsy51739488 try USB connection and refirmware with latest UIFlow FW
        • lukasmaximusL Offline
          Hi @lsy51739488 I just tested Stick C on both beta and 1.3.2 Uiflow with no connection issues. I was using firmware 1.3.5 firmware but older firmwares should also work fine. Are you still having issues?
          With your input, this post could be even better šŸ’—
