    Code download does not properly work for UI flow
    UIFlow
    uiflow
    8.1k
      star1120
      Hi, I'm using M5FIRE with UIflow.
      What I'm doing is sending ENV. sensor data to server.
      The code I wrote works when I just run the code from RUN button on UI flow web, but does not work when I download the code on M5FIRE from download button.
      Is there any possible issue and solution?
      • H
        heybin
        please add this block
          star1120 @heybin
          @heybin It works now!! Thank you so much
