    M5Stack - Base - Node - Testcode
    Modules
    11.9k
    • MrTarantlM
      MrTarantl
      Here is some testcode for everybody to get started in Platformio (Arduino)
      https://github.com/captFuture/M5Stack---EnvNode
      • Unfortunately i could not get the i2S Dac output to work yet, maybe someone has a clue.
      Don't just talk... create and make
      mickM 1 Reply Last reply Reply Quote 0
      • mickM
        mick @MrTarantl
        @mrtarantl
        Hello MrT,
        Any luck with getting audio up and running on the NODE?
        Cheers
        • MrTarantlM
          MrTarantl
          Sorry - not yet - i would need some help there - i have the audio libraries in place and the pins should be correct but when playing testsounds i only hear squealing noises :(
          • MrTarantlM
            MrTarantl
            I was trying hard to get this working yesterday and used the sample from http://forum.m5stack.com/topic/143/lesson-6-1-speaker-mp3-player/2
            Tried to reconfigure the dac output by changing the following according to the information here https://docs.m5stack.com/#/en/base/node_base
            out = new AudioOutputI2S(0,0);
            //#define I2S_WS 13 //LRCLK - Frame clock
            //#define I2S_BCK 5 //BCLK - Bit clock
            //#define I2S_IN 2 //DACDAT - Serial data input.
            //SetPinout(int bclk, int wclk, int dout)
            out->SetPinout(I2S_BCK, I2S_WS, I2S_IN);
            out->SetOutputModeMono(true);
            mp3 = new AudioGeneratorMP3();
            playing = true;
            mp3->begin(id3, out);
            but no luck -> the file still got played through the internal speaker.
            Maybe somebody has a clue how to proceed
            • MrTarantlM
              MrTarantl
              Sorry, i have to give up on this. Something strange happened yesterday.
              After getting quite bad sound quality out of the node module i did something else and suddenly i heard a bang, followed by a strange smell.
              After unplugging and disassembling i found at least one capacitor dead in the module.
              Pcb
              Have not decided if i salvage some parts or try to get at least the leds and the IR back into function ... currently it is just heating up when i power it.
