    GPIO17 does not works
    FACES Kit
    7.9k
    • P
      progman
      void gpio17(  )
        Serial.println( "gpio17" );
      void setup( )
      	M5.begin( true, false, false, true );
      	Wire.begin();
      	pinMode( KEYBOARD_INT, INPUT_PULLUP );
      	pinMode( 17, INPUT );
      	attachInterrupt( digitalPinToInterrupt( 17 ), gpio17, RISING );
      I send signal but nothing.
      M5Stack BASIC Kit GPIO17 works correct
        What is the error message?
        • P
          progman @ajb2k3
          @ajb2k3 No error. Interrupt functions gpio17 does not called
          PS I build sketch with "Debug off" but with "Debug: Serial" same problem, Function does not called
          PPS GPIO 17 works ok if I remove FaceKit and use M5Stack GRAY separately. So, as I understand it is hardware problem of FaceKit only.
          • lukasmaximusL
            @progman I was told by one of our engineers that gpio5 is the interrupt pin on the faces kit
