    Unable to run UIFlow or M5Burner on Win10
    21 Posts 13 Posters 36.8k Views 2 Watching
    • Z Offline
      Zorfox
      I have downloaded both M5Burner.zip and UIFlow-Desktop-IDE. After extraction(s) I am unable to run either applications, UIFlow-Desktop-IDE.exe and M5Burner.exe. When double clicking the files I see a wait icon for a few seconds and nothing happens. I also tried running from command promt. I have attempted running as administrator as well as using all compatibility settings available.
      Any ideas? I must be missing the obvious but simply don't see it.
        You need to download M5Burner from inside UIFlow (online) the extract to a folder. Copy m5burner.exe and uiflow into the folder over writing existing files.
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          Zorfox @ajb2k3
          The m5burner file download from UIFlow is the same zip file I posted. Never the less, I have extracted both files to their folder, M5Burner (download via UIFlow web interface) and UIFlow-Desktop-IDE. You say to copy m5burner.exe and UIFlow-Desktop-IDE.exe to the folder. Which folder are you referring to? Sorry, this makes no sense to me.
          I watched the offline version video, contained in the UIflow web app. I downloaded, extracted and double clicked on the file exactly as you did. The app ran for you but not for me.
          Sorry I'm not understanding what your trying to explain. Thanks for your prompt reply!
          • OyczEO Offline
            OyczE
            Its not a problem with antivirus ?
            Or simple run As Administrator ?
            As i remember at very first run my Norton AV cry and ask about what todo after start ide and burner.
            Lem us know with Windows build you have. I have no problems on 10.0.16299.1365 and latest insider fast ring.
            • Z Offline
              Zorfox @OyczE
              @mati That is an excellent idea! Unfortunately, I just tried disabling my antivirus and firewall without success. In fact, I tried running the files on my Wife's laptop (Windows 7) and had the same issue. As far as running as administrator, I previously tried this as well. Below is the operating system details as requested. However, since it didn't run on another PC using a different OS I doubt it's related to which system I'm using. Thanks for the reply. It was in fact something I had not considered.
              Edition: Windows 10 Home
              Version: 1803
              OS Build: 17134.950
              G OyczEO G 3 Replies Last reply Reply Quote 0
              • G Offline
                Gaviota @Zorfox
                Hi @zorfox, during first start up of my m5stack i went also in problems with m5burner.
                On a second laptop the m5burner runs well.
                Then back to the first laptop it runs, but i took an other usb-port.
                Test other usb-ports at your pc, may be that this is the problems solution.
                • OyczEO Offline
                  OyczE @Zorfox
                  @zorfox said in Unable to run UIFlow or M5Burner on Win10:
                  Version: 1803
                  OS Build: 17134.950
                  ok let's go deeper ..
                  M5Burner after small debug looks like need a Visual C++ Redistributable for Visual Studio 2015
                  https://www.microsoft.com/en-US/download/details.aspx?id=48145
                  since i have visual studio code installed all old and C++ stuff is installed.
                  Try to follow this path. This is strange we have nothing about req to run this. Also node.js is installed on my both systems.
                  And some more...
                  Inside M5burner after repack in root folder we have M5burner.exe with is shortcut to \bin\M5Burner.exe with is 91 758KB file. i guess you have try it as well.
                  M5burner looks like its node.js electron .exe so try to check in %LOCALAPPDATA%\CrashDumps if there is any crash file with m5burner.exe
                  Ultimate solution and tryout is grab this VM winsows 10 with all visual studio stuff:
                  https://developer.microsoft.com/en-us/windows/downloads/virtual-machines
                  reffer:
                  The file signature has been detected,signature: Microsoft Visual C# v7.0 / Basic .NET,5
                  https://electronjs.org/docs/tutorial/windows-store-guide system req spec to run electron .exe
                  And last one if you are working on Acer NB/DT check this out ;D
                  https://github.com/electron-userland/electron-prebuilt-compile/issues/36
                  • Z Offline
                    Zorfox @OyczE
                    @mati Hello Mati,
                    Thanks for your reply and I'm sorry for the delayed response.
                    I did have the C++ redistributable installed, Microsoft Visual C++ Redistributable (x86) 14.0.24215.1. I have Visual studio installed on this machine. Therefore, I have many of the libraries such as C++, J#, .NET framework, etc. My OS is also up to date on all the updates, including the anniversary update which appears to be needed for electron applications.
                    I did not have node.js installed. I went ahead and installed it. However, I am still experiencing the same issue.
                    Running the \bin\M5Burner.exe file displays a prompt,
                    "This app can't run on your PC. To find a version for your PC, check with the software publisher."
                    This does not appear when running the shortcut executable.
                    I did not have any M5burner dump files. I did have several for UIflow however. I can send them to you if need be. I'm not able to read nor understand the contents of the report(s).
                    The virtual machine is a good idea. Unfortunately, my internet speed is only 10mbs and a few gigabytes would take ALONG time. Even if it worked it would not solve my primary issue.
                    As far as the machine I use, it's not an ACER. It's a desktop that I put together myself.
                    I appreciate all your effort!
                    • OyczEO Offline
                      OyczE @Zorfox
                      @zorfox i have bad news for you, all works fine in VM, please check it out, after launch m5burner.exe i have to confirm and expand More info to run it. Then windows will recognize what is missing and autodownload will take a action. At end after relaunch all is fine ...
                      Did you saw this ?
                      VM from MS have to be pimped to 8GB of Vram and 8 vCPU's, default 2G and 1CPU was to lazy.
                      text alternatywny
                      In any case of follow up i have no clue what else we can do. Its last chance in M5stack tech support via mail.
                      • L Offline
                        liushasha
                        Its might caused by the 'windows defender' set at a high-security level. Try to lower the security level.
                        At the top item unselect forbidden to warning.
                        • L Offline
                          Lupa13 @liushasha
                          @liushasha Same problem here !! :-(
                          When I open the M5burner exe file (last version on m5doc site is M5Burner-v3-beta-win-x64) nothing happens. All I get is a black screen. (The left side of it is ok -shows all the options (CORE, Stick C, Atom...etc)
                          I did received that blue screen of Windows Defender but clicking on "More Info", you can install it anyway....
                          But tried also going to Windows Defender page and disabling the apps and files verification (Nothing happened). Tried disbling the AVAST antivirus (nothing again)
                          Is there a M5burner exe "not beta" working ???
                          Thanks !
                            ajb2k3 @Lupa13
                            @Lupa13 Have you installed the latest python and have you installed ESPTools ?
                            • G Offline
                              getsmod @Zorfox
                              @Zorfox said in Unable to run UIFlow or M5Burner on Win10:
                              Version: 1803
                              OS Build: 17134.950
                              Tried disabling antivirus/firewall, and running on a different PC—same issue. Admin mode didn’t help either. Appreciate the suggestion though!
                                hector01 @Zorfox
                                It seems like a missing dependency or blocked execution issue. Try disabling antivirus, installing required drivers, or checking port 7181 usage. Also, verify system requirements and reinstall both applications. Let me know!
                                  peolsolutions
                                  Update your system and install the latest version of UIFlow or M5Burner if they are not running on Windows 10. Ensure that the CP210x USB to UART drivers have been installed. Ensure that the software is run as an Administrator and that conflicting applications using the COM port are closed. Disable your antivirus/firewall temporarily and reinstall the software if necessary. As a result of these steps, connectivity and execution issues can be resolved, ensuring that M5Stack tools operate smoothly.
                                  • E Offline
                                    ehsaas8171bisp
                                    That’s a great suggestion! Unfortunately, I already tried disabling both my antivirus and firewall, but the issue persisted. I even attempted to run the files on my wife’s laptop, which is running Windows 7, and encountered the same problem. I had previously tried running the program as an administrator as well.
                                    Below are the operating system details as requested. However, since the issue occurs on a different computer with a different OS, I suspect it’s not related to my specific system.
                                      peolsolutions
                                      If you’re unable to run UIFlow or M5Burner on Windows 10, try running the app as administrator and ensure all necessary USB drivers (like CP210x or CH340) are installed. Disable antivirus temporarily, update your .NET framework, and check if the device is recognized in Device Manager. Reinstall the latest version from the official M5Stack site. Compatibility mode and checking firewall settings can also help resolve startup or connection issues.
                                        Riolab
                                        I faced the same problem a while back. Updating the USB drivers and reinstalling the software worked for me. You might also want to restart your PC after the update that seemed to help.
                                          adamsmith12
                                          Good.
                                            adamsmith12
                                            It's good to see such discussions.
