    M5burner on windows7 cannot flash
    28 Posts 5 Posters 103.3k Views 1 Watching
    • Ariane98A Offline
      Ariane98
      ok...I used another PC and now I can connect
      Now I try to use gyro and accelerometer but when I use get X acc or get X gyr it says Execute code successfully but the stick says I2C bus error(6)
      Do you have an example of using IMU with UIFlow?
        Thrasher @Ariane98
        @ariane98 show us your code
        Ariane98A 1 Reply Last reply Reply Quote 0
        • Ariane98A Offline
          Ariane98 @Thrasher
          from m5stack import *
          from m5ui import *
          from uiflow import *
          import imu
          setScreenColor(0x111111)
          imu0 = imu.IMU()
          label0 = M5TextBox(27, 7, "AccX", lcd.FONT_Default,0xFFFFFF, rotate=0)
          setScreenColor(0x33ff33)
          lcd.font(lcd.FONT_DejaVu24)
          lcd.print('FelX', 10, 30, 0xcc33cc)
          wait(3)
          while True:
          label0.setText(str(imu0.acceleration[0]))
          wait(1)
          wait_ms(2)
          • Ariane98A Offline
            Ariane98
            when I try the exact same blocks than in https://www.youtube.com/watch?v=zNxKkfbEkKU (label show get X gyr), I get this "I2C bus error(6)"
            • Ariane98A Offline
              Ariane98
              and from arduino IDE I get values from IMU
              So I guess it has with UIFlow interface to do ?
                Your first issue on the first PC is that for some reason UIFlow is looking at the 2.7 version and not the 3.6 version of python. Check your python environmental setup as this happens if the environment is wrong (I used to get this often when running 2 version of python.
                Second issue. what hardware are you running, what firmware version are you running and what version of UIFlow are you running?
                It sounds like you haven't got UIFlow set to M5Stick.
                • Ariane98A Offline
                  Ariane98
                  Code runs on the stick, excepted whan I try to use IMU.
                  Both firmware and UIFlow are UIFlowv1.3.2
                  ajb2k3A Ariane98A 2 Replies Last reply Reply Quote 0
                    ajb2k3 @Ariane98
                    @ariane98 Which stick?
                    The old black or the Orange Stick C?
                    • Ariane98A Offline
                      Ariane98 @Ariane98
                      Orange
                      • Ariane98A Offline
                        Ariane98
                        btw, in arduino, how do you access the built in red led?
                        Docs showed pin 10 but it's no working...
                          ajb2k3 @Ariane98
                          @ariane98 said in M5burner on windows7 cannot flash:
                          Try GPIO10
                          • Ariane98A Offline
                            Ariane98 @ajb2k3
                            Strangely, it does light the led when I use digitalWrite(10, HIGH) but then nothing happens with digitalWrite(10, LOW)
                            If I use digitalWrite(10, LOW) first, it sets the led ON...
                              Ok I'm running 1.4 and getting a syntex error.
                              Try upgrading to 1.4.0 beta and try again.
                              • Ariane98A Offline
                                Ariane98 @ajb2k3
                                Thanks for your help
                                I intended to use m5stick with kids but maybe it's too early...
                                Both UIFlow and Arduino environments seem still unpredictable
                                  ajb2k3 @Ariane98
                                  @ariane98 Its strange because all I use is UIFlow and I am writing an english book on it (samples available to download in the projects forum)
                                  For the current M5StickC competition i'm using the IMU in my project however, I'm using the online version and programming over wifi.
                                  • Ariane98A Offline
                                    Ariane98 @ajb2k3
                                    I am using UIFlow online too, but no luck with IMU...
                                    • Ariane98A Offline
                                      Ariane98 @ajb2k3
                                      is it possible too use the stick as a vry simple webserver?
                                        Don't know about the web server but here is my imu test file
                                        https://github.com/Ajb2k3/UIFlowHandbook/blob/master/main (8).m5f
                                        • Ariane98A Offline
                                          Ariane98 @ajb2k3
                                          I get the same I2C bus error
                                          If I upload it to the stick I get a grey screen with no data displayed
                                          • Ariane98A Offline
                                            Ariane98 @Ariane98
                                            updated to 1.4.0 beta and that's OK now
                                            Thank you
                                            I've looked at your book...quite nice
