    All my M5Stack/Stick sketch doesn't compile anymore
    3 Posts 2 Posters 6.3k Views 1 Watching
      cepics
      Hi all,
      after some test with FACES firmware on my osx machine following this doc and upgrade M5stack library, now I can't verify/compile NONE of my M5Stack/Stick sketch.
      this is the arduino IDE output:
      Arduino: 1.8.9 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
      /Users/ce/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
      /Users/ce/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
         gpio_deep_sleep_hold_dis();
      Multiple libraries were found for "SPI.h"
       Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
       Not used: /Users/ce/Documents/Arduino/libraries/SPI
       Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/SD
       Not used: /Users/ce/Documents/Arduino/libraries/SD
       Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/SD
       Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/WiFi
       Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/WiFi
      Multiple libraries were found for "RunningMedian.h"
       Used: /Users/ce/Documents/Arduino/libraries/RunningMedian
       Not used: /Users/ce/Documents/Arduino/libraries/RunningMedianOLD
      exit status 1
      (the other sketch for arduino mega and Uno compile normally)
      Please Help
      tnks a lot
      • G Offline
        Gaviota @cepics
        @cepics said in All my M5Stack/Stick sketch doesn't compile anymore:
        You have installed multiple libraries
        Use the option "Show verbose output during compilation", as shown in the compiler message, to get more information about the problem.
          cepics
          solved on commenting out
          in
          I don't know why, but now arduino compile
