    Multiple TOF units: VL53L0X
    7.8k
    • H
      henk_m5stack
      Hello
      I want to use two M5stack VL53L0X TOF flight units on a Arduino board. How do I change the adress in I2C so that they are both recognized? In demo of the Arduino Adafruit library "VL53l0x dual" pins are assigned by using the SHT pin. But the M5 unit does not have that??
      TXS.
        ajb2k3 @henk_m5stack
        @henk_m5stack You can reset the address but it is easer to use the PaHub. I'm using 2x Tof in uiflow on a lego robot.
        • H
          henk_m5stack @ajb2k3
          Hallo
          Where can i find how to do it?
            @henk_m5stack said in Multiple TOF units: VL53L0X:
            Hallo
            in arduino look up the TCA9548A, there are lots of librarys and guides for it.
            Also @lukasmaximus89 made a video of it https://www.youtube.com/watch?v=nMsCwqCE5c8&t=10s
            In UIFlow its very simple.
            • H
              henk_m5stack
              Hi
              Txs, I found it and will order one. It is indeed the most easy sollution.
              Henk.
