    Unable to wake M5StickC using SH200Q's activity interrupt
    M5 Stick/StickC
    7.7k
      marsalkm
      According to some of the documentation (and a random issue on GitHub), the SH200Q should be hooked up to GPIO35 to wake the stick from deep sleep upon activity. While running, I can see this interrupt being triggered, but it never actually wakes from deep sleep.
      Here's the code I use to set up the interrupt:
      // Enable acc interrupt
        buf = 1<<1;
        M5.IMU.I2C_Write_NBytes(SH200I_ADDRESS, 0x14, 1, &buf);
        // Set acc threshold
        buf = 100;
        M5.IMU.I2C_Write_NBytes(SH200I_ADDRESS, 0x17, 1, &buf);
        // Set amount of time acc must be in threshold before interrupt is triggered
        buf = 4;
        M5.IMU.I2C_Write_NBytes(SH200I_ADDRESS, 0x19, 1, &buf);
        // set gyro x/y/z as inputs for interrupt (bit 7 enables the use of TIME_THRESHOLD)
        buf = 1<<4 | 1<<5 | 1<<6 | 1<<7;
        M5.IMU.I2C_Write_NBytes(SH200I_ADDRESS, 0x1B, 1, &buf);
      And this is the line that should enable wake on GPIO35 activity:
      esp_sleep_enable_ext0_wakeup((gpio_num_t)35, 1); // set ext0 to wake up when GPIO35 is high
      I've also tried enabling wakeup on one of the external M5Stick buttons as a sanity check.. that worked fine.
      My question; is the SH200Q's interrupt actually hooked up to anything, and if so what? Or is there some error in my code?
      • V
        vany5921
        IMU does not control GPIO35 to issue an interrupt
        • D
          davesee
          Should this work when using the M5StickC model with the MPU6886 IMU?
          The schematic suggests that GPIO35 is wired to the external interrupt of the MPU6886 https://docs.m5stack.com/#/en/core/m5stickc
          Cheers,
          Dave
          • D
            davesee
            @marsalkm This ability should work on M5StickC units with the MPU6886. There's more info on this thread here:
            https://community.m5stack.com/topic/2039/wake-up-on-pick-up
