    HPWR for external peripherals?
    General
    iot esp-32 esp-8266
    14.8k
    • A
      ashwindec11
      I have a project where I need to power some 12V devices; what would be a good way to achieve this? I see the HPWR label but which pins would I use as the M5Bottom re-assigns them (and the base26 has 2 set as R2/T2 with the 3rd as Vin). So far I’m thinking attach a header to base 26 then use the Vin pin and a ground pin and maybe use another for the logic.
      • T
        Thrasher
        Hi
        I think best way is to power them separetly from M5Stack while using same ground line.
        • A
          ashwindec11
          That could be a way but I want to keep everything together (otherwise why use something nice and concise like M5Stack when I could just use a breadboard with wires everywhere and multiple power inputs). The input for the core can be 12V so I thought why not use that as the input for the other stuff (heater, fan, motor, etc).
            ajb2k3 @ashwindec11
            @ashwindec11 No, the input to the core cannot be powered from 12v it is only a 5v or a 3.3v.
            to use 12v you need to provide an additional adapter. the stackable module have built in power adapters to take the 12v and supply 5 volt to the M5Stack bus
            • A
              ashwindec11
              Ah okay, so how does the stepper module work for power? Also what is HPWR?
                ajb2k3 @ashwindec11
                @ashwindec11 said in HPWR for external peripherals?:
                The modules use an LM2596sx to drop the power from 12 to 5v befor feeding it to the 5v pin.
                • A
                  ashwindec11 @ajb2k3
                  Ah okay, so what does HPWR do? And aren’t the motors 12V?
                    ajb2k3 @ashwindec11
                    @ashwindec11 yes, the motors are 12v and are fed from the 12v side of the LM2596SX, the logic and core are fed from the 5v side of the LM2596SX
