๐Ÿค–Have you ever tried Chat.M5Stack.com before asking??๐Ÿ˜Ž
    M5stack V uart communication
    Scheduled Pinned Locked Moved M5Stick V
    5 Posts 4 Posters 16.0k Views 1 Watching
      jarain78
      Hello everyone, does anyone know how I can connect my M5Stick V to my M5Stack Fire using serial communication? These are a part of the codes I use.
      Stick-V
      import time
      from machine import UART
      from fpioa_manager import fm
      fm.register(35, fm.fpioa.UART2_TX, force=True)
      fm.register(34, fm.fpioa.UART2_RX, force=True)
      uart = UART(UART.UART2, 9600)
      while(True):
      uart.write("Hello World!\r")
      time.sleep(1000)
      Stack-Fire
      #include <M5Stack.h> // needed for my board M5Stack
      HardwareSerial m5stack_uart(2);
      void setup()
      Serial.begin(9600); ;
      m5stack_uart.begin(9600, SERIAL_8N1, 16, 17);
      //Serial2_.flush();
      Serial.println("Hola");
      m5stack_uart.println("Hola");
      void loop()
      m5stack_uart.println("@");
      if (m5stack_uart.available()) {
      String s = m5stack_uart.readString();
      Serial.println(s);
      if (Serial.available()) {
      String s = Serial.readString();
      m5stack_uart.println(s);
      Regards
      Jaime
        staberas
        https://m5stack.hackster.io/anoken2017/cheering-watch-of-m5stickc-v-34f0cc
        Near the end , tell us if it helps
        • V Offline
          vvs551
          https://qiita.com/nnn112358/items/5efd926fea20cd6c2c43
            jarain78
            Problem solved, thanks to both of you for the suggestions.
            Thank you
            Jaime
              syphax_halou
              Hello, I also bought the same m5stack and m5stick v products, I have the same problem. can you help me to be able to communicate my camera with the m5stack, knowing that I program my camera with maixpy โ€‹โ€‹and the m5stack with arduino thank you in advance.
              With your input, this post could be even better ๐Ÿ’—
