    M5Stack Fire and Balance Car Pogo Pins not fully engaged?
    Scheduled Pinned Locked Moved Bases
    2 Posts 2 Posters 6.4k Views 1 Watching
      Happy Hippo
      I notice that when I put the M5Stack Fire on top of the balance car base, I can see a substantial gap. Is that supposed to be that way? (see picture). Also, I have the same problem with the charging cable with pogo pins on it. The charging cable does not stay connected. Seems like the pogo pins are stronger than the magnets. Is there some trick to using that charging cable?!0_1573409443266_IMG_20191110_130420.jpg
      • lukasmaximusL Offline
        Hi @Happy-Hippo if you press the pogo pins do they spring back fully? or get lodged? usually there is a bit of a gap but it shouldn't affect normal operation
