    M5stick frequently disconnected
    UIFlow
    15.5k
    • Ariane98A
      Ariane98
      Hi, dear UIFlow users
      I purchased a M5stick a few weeks ago, and was able to have fun programming it with UIFlow. So I thought I would use these things for workshops with kids, and I bought some more M5Stick. Then I used M5 burner to get them ready
      Unfortunately, when I try to "Run" the code, UIFlow usually says the stick is disconnected. Every 3, 6 or 10 times it does upload the code though. That is very annoying...
      I tried many sticks, many version (both firmware and UIFlow)...with no luck
      The sticks do connect to my wifi network, I can ping them
      If someone had hints/clues/... it would be great !
        If this is more apparent on Saturdays and sundays, it is down to server overload. This happens quite regularly
        • Ariane98A
          Ariane98
          I noticed that today...maybe 11:11 is as busy as a week end?!
          Is there a way to install a private server (local or remote)?
          • lukasmaximusL
            Hi @Ariane98 just to confirm are your devices M5StickC or original M5Stick(monochrome oled version), Are you having issues with the Uiflow offline version? and what version of the firmware are you running?
            Ariane98A 1 Reply Last reply Reply Quote 0
            • Ariane98A
              Ariane98 @lukasmaximus
              @lukasmaximus
              Hi
              It's somewhat better today, but I still have to try 3 times before it connects/uploads
              It's the orange stick M5StickC
              I tried firmware 1.4.0 and 1.4.1
              I did not try offline UIFlow yet
              • lukasmaximusL
                Recently we are having more issues due to increased activity, Last time I heard we only have one server in Singapore, but we are working on getting hosted in more countries. You can try the offline version here https://m5stack.com/pages/download make sure to put your m5stickC into usb mode by pressing the m5 button on reboot and using the right hand side button to scroll through the menus into setup, then choose usb mode from the list
                • Ariane98A
                  Ariane98
                  I guess the USB thing is only for offline version ? (I've never used it before)
                    ajb2k3 @Ariane98
                    @ariane98 Yes, for off line programming.
