    M5Stack with External Speaker
    PROJECTS
    11.3k
    • C
      creativetabi
      I'm a newbie in M5Stack.
      I would like to know if it's possible to turn off the M5Stack internal speaker and connect it to an external speaker (or vibrotransducer)?
      I use the following vibrotransducer as my speaker: http://www.acouve.co.jp/product/pd_vp2.html
      And PAM8403 amplifier.
      Can anyone teach me how to connect all the parts with a schematic diagram (if possible)?
      Thank you in advance.
      Best regards!
      • lukasmaximusL
        Hi @creativetabi which M5Stack are you using? If you have the black or grey core this is easy. You just need to connect a wire up to pin 25 which is the DAC connected to the speaker, and another wire to ground and you should be able to get the sound signal from the M5stack
        • C
          creativetabi
          Hi @lukasmaximus, I'm using the black core M5Stack.
          I've tried what you suggested and now it's ok already. :)
          Thank you so much for your help.
          • lukasmaximusL
            No worries, glad it worked for you. Are you making a musical project?
            I would love to hear about it
            • C
              creativetabi @lukasmaximus
              @lukasmaximus Yes.. I want to make an audio-haptic installation for a school project. :) And now I'm trying to make it wireless. By any chance, do you know how to send data from MAX/MSP to M5Stack (via udp, WiFi)?
