    Graphing calculator
    Scheduled Pinned Locked Moved FACES Kit
    8 Posts 3 Posters 17.8k Views 1 Watching
    • B Offline
      BitBoy01
      Hey,
      is it possible to program a graphing calculator with micropython using the keyboard? I already have a code for a graphing calculator. I used Python. How can I use it with the m5stack?
      Thank you, I'm a total beginner!
      • m5stackM Online
        hi , if you want to use Face Devide program a graphing calculator application , you can use UIFlow to program it.
        http://flow.m5stack.com/
        • B Offline
          BitBoy01
          Thanks for the reply.
          Is there no way of doing it with micropython?
          • m5stackM Online
            m5stack @BitBoy01
            @bitboy01 actually UIFlow can use Blockly and Micropython two program way
              Thrasher
              @BitBoy01 You can do raw micropython with VS Code and M5Stack plugin
              UIFlow allows to code directly with micropython too but I had no success saving code on HDD and its not convinient for me at all.
              • B Offline
                BitBoy01
                okay, I installed UIFlow on the M5Stack and I have VS Code now. How can I change the code so that it works on the M5Stack? Do all python modules work micropython?
                • m5stackM Online
                  m5stack @BitBoy01
                  @bitboy01
                  github readme will show you how to start programing with VSCode
                  https://github.com/m5stack/UIFlow-Code
                  • B Offline
                    BitBoy01
                    this is literally what I needed. thank you very much!
