    Uploading to M5STACK BASIC DevKit
    Cores
    7.5k
    • V
      vibi27
      I've got a black M5STACK BASIC DevKit from amazon today.
      Expected to see a SubCATEGORIES "M5Stack core" or "M5Stack Black" on this forum.
      I'm developping on WIN10, using PlatformIO, latest M5STACK lib (with this platformio.ini:
      [env:m5stack-core-esp32]
      platform = espressif32
      board = m5stack-core-esp32
      framework = arduino
      Tried some examples, with no success (black screen).
      Uploaded successfully first program:
      #include <M5stack.h>
      M5.begin(true, false, true); // Cause no SD card inside
      M5.Lcd.print("Hello Vince");
      M5.update();
      Then tried this program:
      M5.Lcd.fillScreen(WHITE);
      M5.Lcd.setCursor(100, 100);
      M5.Lcd.setTextColor(RED);
      M5.Lcd.setTextSize(5);
      M5.update();
      Unfortunatly, the second program always displays same as the first program (white text on black screen)
      My programming method is simple: click the "PlatformIO: upload" button, wait for percentage progress, and look at the screen.
      Am I missing something ?
      Second question: with this M5Stack-Black, do I need to call M5.Power.begin() after M5.begin(), and what are the consequences if I do not ?
      Thanks for your responses
      • V
        vibi27
        Same code works on Arduino IDE 1.8.10
        Also tried to remove .pio/build directory to force a full rebuild on Platformio, with no success.
        • V
          vibi27
          With updated versions it works well know.
          For the record here are the different versions involved:
          OS: Windows 10 64 bits
          Latest USB driver (CP2104 installed by ArduinoIDE 1.8.10 if I remember well) for ESP32.
          IDE: VisualStudioCode V1.41.1 with PlatformIO
          Espressif 32 V1.11.1
          M5Stack 0.2.9
          PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), framework-arduinoespressif32 2.10004.191002 (1.0.4), tool-esptoolpy 1.20600.0 (2.6.0), tool-mkspiffs 2.230.0 (2.30)
          Platformio.ini flags:
          framework = arduino
          monitor_speed=115200
          #upload_port =COM6
          upload_speed=921600
          • V
            vibi27
            I don't know how to edit the title to put [SOLVED] into it.
              macsbug @vibi27
                macsbug @macsbug
