    m5Stack Fire & GPS UIflow > sintax error Why?
    12 Posts 3 Posters 23.4k Views 1 Watching
      Thrasher
      It says syntax error, so we better see py code, not blocks. Could you switch to code view and post here?
      For me, setup should not be inside loop. Separate them and try again
        almeriBOT
          almeriBOT
          The biggest problem is that it doesn't show the data
          In the time field it says 00:00:00
          The rest of the fields (latitude, longitude, number of satellites and quality) do not appear data
          I have updated to the latest version 1.4.2
          • m5stackM Offline
            m5stack @almeriBOT
            @almeribot hi maybe just the signal not good , you can go to the outdoor then try a again
              almeriBOT @m5stack
              @m5stack Thank you very much for the reply. I was testing the GPS for more than an hour in an outdoor location
              • m5stackM Offline
                m5stack @almeriBOT
                @almeribot so it still doesn't show the data ?
                  almeriBOT
                  I just received an m5Stick. The same program does work on m5Stick. Now I don't understand anything.
                    almeriBOT
                      almeriBOT
                        almeriBOT
                          almeriBOT
