    UI Flow loses connection to device after uploding demo example
    M5 Stick/StickC
    3.2k
    • E
      emrem6
      When I upload an demo example on the M5 stick c the connection to device gets lost and I cannot reconnect again. It discplays on the bottom left side "Disconnected" and after pushing the "Refresh device status" button it throws the error message "Upload code failed, maybe your device is offline check it and retry" .
      How to solve this?
      • OyczEO
        OyczE
        This is normal in ueflow.
        Turn it off.
        Hold right button then push power.
        Then when screen wake up release side button and push it again to force cloud.
        Other way is turn off
        Hold bug button under LCD and power it on.
        then by using right button in under the LCD you can navigate on lets say boot manu.
