    M5stick from PlatformIO
    10.2k
    • Ariane98A
      Ariane98
      Hi
      Having problems with UIFlow, I tried PlatformIO to program the M5stick.
      I was able to upload the "arduino-wifiscan" but then I wanted to print Wifi infos on the screen. I thought I had to #include <M5StickC.h> but it "gets red" and says I should update includePath
      Why/how do I do that ?
      I tried "pio lib install "M5StickC" and no more red alert...for a while, but then error again about includePath
      If someone had a simple step by step setup for the M5StickC it would help me a lot...
      • N
        nsfilho
        You need to change your lib_deps in platformio.ini, as the sample bellow:
        [env:m5stick-c]
        platform = espressif32
        board = m5stick-c
        framework = arduino
        lib_deps = M5StickC
        monitor_speed = 115200
        • hagueH
          hague
          Another simple solution is to download the library and put all files from the /src directory directly it in the /src directory from your PlatformIO project.
          Link to the library:
          https://github.com/m5stack/M5StickC
          Then you can include the header file like this:
          #include "M5StickC.h"
          Not exactly the most beautiful solution, but it works...
          • N
            nsfilho @hague
            @hague I could be wrong, but I believe if you use as lib_deps is a better solution, because the PlatformIO can update automatically the library in the future. Not only that, your code build more faster (because the library use a shared objects - *.o files).
            Other interesting point is to add more libraries to project. But again, this is IMHO about the way to use PlatformIO.
