Overwrite with "printf" command
I'm trying to put on the lcd a number with the command "printf", but the screen writes the number over the previous one, so the result is a colored square in a short time.
I attach the code I'm using in case anyone can help me, thanks in advance.#include <M5Stack.h>
double tiempoSegundos= 0;
void Printseg() // Presenta los seg en pantalla
M5.lcd.setCursor(0,180);
M5.Lcd.printf(" %6.3f",tiempoSegundos );
M5.begin(); // inicio del M5S:…..
Printseg(); } -
1 clear whole screen before print (possible flicker screen)
2 print same text on the same position with background color
3 draw filled rectangle with background color that cover area where text was printed -
Yes, correct I used the " M5.Lcd.setTextColor (YELLOW, BLACK);" in the setup command , and effectively overwriting by deleting the above. Thank you.
Greetings.
