    Upload error w Arduino IDE - A fatal error... Timed out waiting for packet header
    4 Posts 4 Posters 8.3k Views 1 Watching
      mlewi70
      Hi M5Stack C sitting on win 10 (Dell XPS 15), COM5. EasyLoader looks to connect and work fine. But, Arduino IDE runs into this problem when trying to upload a sketch("Hello World").
      I have tried different things, like connecting GND-G0 and 3V3-G0. No success.
      Sketch uses 254233 bytes (19%) of program storage space. Maximum is 1310720 bytes.
      Global variables use 16676 bytes (5%) of dynamic memory, leaving 311004 bytes for local variables. Maximum is 327680 bytes.
      esptool.py v2.6
      Serial port COM5
      Connecting.....
      Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None
      MAC: d8:a0:1d:56:47:60
      Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 921600
      Changed.
      Configuring flash size...
      A fatal error occurred: Timed out waiting for packet header
      • sysdl132S Offline
        sysdl132
        That isnt a big trouble.A photo about it is helpful...
        you can try to dissconnect from your USB port and then reconnect and upload.Do not touch the line while you are uploading.
        I think you touched the USB line while uploading.
        For Atom:115200/230400/921600
          Have you tried changing the baud rates?
          There are many reasons for the timeout.
          • m5stackM Online
            Hi, you should selcet M5StickC board in ther board manager. or seting the baud rate to 115200
