    Description M5Stack 6060-PUSH
    13 Posts 4 Posters 25.4k Views 1 Watching
      sheepDog
      I am missing some information at docs of M5Stack 6060-Push.
      1. Where can I find the pinout of the orange connector of M5Stack 6060-Push? At this connector there are power and RS485. Inside the modul I found: G, V, A and B.
        I suspected:
      • G = GND
      • V = +24V (or other voltage?)
      • A = RS485-A
      • B = RS485-B
      1. Which command are available?
      • ID\r\n -> Get the ID of the modul - I understood
      • ID=<number> -> Set the ID - I understood
      • ID<number>:X<position> \r\n - If <position> equal 010.1 what will happend? Movement 10.1 mm or 10.1 steps?
        -ID<number>I\r\n - Read busy - What is the answer?
        It would be great if I could get some more details.
      • m5stackM Online
        m5stack @sheepDog
        @sheepdog
        you can refer 6060 product document.
        link : https://docs.m5stack.com/#/en/1515/6060-push
          sheepDog
          @m5stack
          I know the link at your answer. At the linked webpage is no information about pinout or details of the commands! Can you help me?
          ajb2k3A m5stackM 2 Replies Last reply Reply Quote 0
            ajb2k3 @sheepDog
            @sheepdog said in Description M5Stack 6060-PUSH:
            @m5stack
            The 6060 Push is not well documented.
            Have you seen this page?
            https://docs.m5stack.com/#/en/uiflow/RS485
            • m5stackM Online
              m5stack @sheepDog
              @sheepdog actually you just need look at the Product Photo . you can found the commands.
                sheepDog @ajb2k3
                @ajb2k3 Thank you for the new link, I didn't know this page
                @m5stack I saw the commands at the product photo, but this didn't answer my questions:
                1. Where is which Pin (G = GND , V = Voltage, RS485-A, RS485-B)
                2. Which voltage is correct? 24V?
                3. What is the answer of the commands, for example -ID<number>I\r\n - Read busy -
                  I share the opinion that the component is currently not well documented. Sorry.
                  ajb2k3 @sheepDog
                  @sheepdog some more information
                  Pins are show here.
                  alt text
                  alt text
                  Voltage is 12 to 24 vdc.
                  https://docs.m5stack.com/#/en/accessory/485t
                  https://docs.m5stack.com/#/en/base/plc_base
                  https://docs.m5stack.com/#/en/app/ac_socket
                    ajb2k3 @ajb2k3
                    @m5stack In the descriptions of RS485 I see mention of a 100 (120 ohm in the picture above) ohm termination resistor. Is this in each of the devices or is it needed?
                    • O Offline
                      option
                      Use one 120ohm resistor in each end of the bus.
                      If unclear try google for "rs485 termination"
                        ajb2k3 @option
                        @option said in Description M5Stack 6060-PUSH:
                        That's what caused me to ask!
                        @option I just need to check with m5stack before recording in my book.
                          sheepDog
                          @ajb2k3 and @option Thank you for your help.
                          • m5stackM Online
                            m5stack @ajb2k3
                            @ajb2k3 Usually not required, it is recommended to add it for long distance communication
                              ajb2k3 @m5stack
                              @m5stack Thanks.
