    Maximum serial speed limited to 500000 baud?
    Cores
    7.4k
    • G
      GunterO
      Can somebody confirm that the maximum "Serial" speed is limited to 500000 baud?
      As soon I set it to 1000000 or 2000000 it stops outputting to the console.
      I have another ESP32 board, which is using a CH340 as UART-USB bridge, and this one is working fine on 2000000 baud.
      Is it a limitation of the CP210x chip used in the M5Stack?
      I'm using a M5Stack Grey.
      Working:
      Serial.begin(500000);
      Not working:
      Serial.begin(2000000);
      Thanks!
      • G
        GunterO
        I stumbled on this restriction again, and dug a bit deeper in the issue.
        It appears that the hardware is not limiting the baudrate, but the M5Stack library. More specifically, M5.begin();
        Luckily, you can skip the UART init, and do it yourself like this:
        M5.begin(true,true,false);
        Serial.flush();
        And now it works for 2000000 baud.
