    Convert to Integer and test of integer give an Error (solved)
    UIFlow
    14.9k
    • P
      Peter
      I am trying to convert a floating point number into an integer or to test if the number is a floating point number. Both attempts end in an error message as soon as a floating point number is really present.
      Here you should see pictures of Blocky, but doesn't work.
      alt text
      alt text
      alt text
      Does anyone have a solution or what am I doing wrong?
      Thanks a lot
      Peter
      I have found my mistake. A string was passed to the function and not a float.
      Now it plays as it should.
      • T
        Thrasher
        You can't, integer supports only complete values without " . "
        Probably adding something like 0.5 to float first and than trying to make it integer will help
        • P
          Peter @Thrasher
          @thrasher
          Thank you Thrasher,
          I know how to round up. I am interested in testing whether a variable contains an integer or a floating point number. I wanted to cut off the fractional part by converting it to integer, subtract the integer from the number of unknown type and if the result is 0 then it is an integer.
          But since the value is probably passed as a string I have to find another way.
          Peter
          • T
            Thrasher
            I never tried myself, but theoretically you can convert float to char string, than split it using C string instructions and than put desired part into integer. Im not sure blockly allows to do such tricks
            • P
              Peter @Thrasher
              @thrasher
              i have tried further and found that the value is not given as text after all. But if I convert it to text and then count the number of "." I get the desired result. In Python there is isinstance() for type determination. But I did not find this in Blockly.
              Peter
              • T
                Thrasher
                @Peter
                I'm sorry, my knowledge is limited with arduino/C, Im at the very beginning with learning python as I literally very short with time.
                However, I don't suggest you to keep trying with blockly as block-building style coding is very limited.
                Better give raw python/c++ a try, as far as I know python will manipulate with your value like its an object unless you force it to use specific data type
                • lukasmaximusL
                  @Peter if you want to add a regular python function that is supported by micropython but not included in blocks you can use the execute block found in the advanced section
                  • P
                    Peter @Thrasher
                    @thrasher
                    I would like to try out the possibilities and limits of Blockly.
                    • P
                      Peter @lukasmaximus
                      @lukasmaximus
                      Thanks for the tip. I hadn't thought of that. I thought I would have to construct my own block.
                      Peter
