    m5stack + sim800l
    Modules
    4.8k
    • N
      Nicolaf899
      To start understanding the functioning of the sim800l module I used the following example:
      //Reset resistance is not soldered. If necessary, weld it yourself.
      #include <M5Stack.h>
      #define RX_PIN 16
      #define TX_PIN 17
      #define RESET_PIN 5
      void header(const char *string, uint16_t color){
      M5.Lcd.fillScreen(color);
      M5.Lcd.setTextSize(1);
      M5.Lcd.setTextColor(TFT_MAGENTA, TFT_BLUE);
      M5.Lcd.fillRect(0, 0, 320, 30, TFT_BLUE);
      M5.Lcd.setTextDatum(TC_DATUM);
      M5.Lcd.drawString(string, 160, 3, 4);
      header("SIM800L AT command", TFT_BLACK);
      M5.Lcd.setTextFont(2);
      M5.Lcd.setTextColor(TFT_WHITE, TFT_BLACK);
      M5.Lcd.drawString("Please use serial port to Test AT command.",0, 35, 2);
      // Host serial communication
      Serial.begin(115200);
      // SIM800L serial communication
      Serial2.begin(115200, SERIAL_8N1, RX_PIN, TX_PIN);
      pinMode(RESET_PIN, OUTPUT);
      //AT instruction write
      if(Serial.available()){
      Serial2.write(Serial.read());
      //AT instruction result
      if(Serial2.available()){
      Serial.write(Serial2.read());
      delay(10);
      I sent some at command to understand if the module worked but apparently it doesn't work. Any suggestions?
      • lukasmaximusL
        Hi @Nicolaf899 I cannot help you here as I was not able to get the sim800l working myself, please refer to the recent topic http://forum.m5stack.com/topic/1785/sim800l-gprs-mqtt I pasted some links there with information about sim800l. Where possible please check if there is a discussion going on about this module and ask your questions there instead of duplicating a thread, thanks
        • N
          Nicolaf899
          @lukasmaximus said in m5stack + sim800l:
          okk thank you
