(SOLVED)M5Stack WIFI Upload file on SD in AP mode
 Hi all I'm looking for a way to upload files on M5Stack SD with M5Stack in Acces point mode.... Is it possible?
 I tried this but without success ( I know this is not access point mode but it could be a starting point..)Connecting ... Connected to myWifi Use IP address: 192.168.0.150 Initializing SD card...Card initialised... file access enabled... HTTP server startedthis is the serial monitor output: This site can’t be reached192.168.0.150 took too long to respond. Try: Checking the connection Checking the proxy and the firewall ERR_CONNECTION_TIMED_OUTpc and M5Stack are in the same wifi network..
 I'm in the Arduino ecosistem..tnks a lot
 This one work on M5Stack!!!!! /* */ #include "M5Stack.h" #include <WiFi.h> #include <WiFiClient.h> #include <WebServer.h> #define ServerVersion "1.0" String webpage = ""; bool SD_present = false; #include "index.h" //Web page header file WebServer server(80); //=============================================================== // Setup //=============================================================== void setup(void) { Serial.begin(115200); Serial.println(); Serial.println("Booting Sketch..."); //ESP32 As access point IP: 192.168.4.1 WiFi.mode(WIFI_AP); //Access Point mode WiFi.softAP("ESPWebServer", "12345678"); //Password length minimum 8 char //---------------------------------------------------------------- Serial.print(F("Initializing SD card...")); if (!SD.begin(TFCARD_CS_PIN, SPI, 40000000)) { // see if the card is present and can be initialised. Wemos SD-Card CS uses D8 Serial.println(F("Card failed or not present, no SD Card data logging possible...")); SD_present = false; } else { Serial.println(F("Card initialised... file access enabled...")); SD_present = true; } ///////////////////////////// Server Commands server.on("/", HomePage); server.on("/download", File_Download); server.on("/upload", File_Upload); server.on("/fupload", HTTP_POST, []() { server.send(200); }, handleFileUpload); ///////////////////////////// End of Request commands server.begin(); Serial.println("HTTP server started"); } //=============================================================== // This routine is executed when you open its IP in browser //=============================================================== void loop(void) { server.handleClient(); delay(1); } // All supporting functions from here... //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void HomePage() { SendHTML_Header(); webpage += F("<a href='/download'><button>Download</button></a>"); webpage += F("<a href='/upload'><button>Upload</button></a>"); append_page_footer(); SendHTML_Content(); SendHTML_Stop(); // Stop is needed because no content length was sent } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void File_Download() { // This gets called twice, the first pass selects the input, the second pass then processes the command line arguments if (server.args() > 0 ) { // Arguments were received if (server.hasArg("download")) SD_file_download(server.arg(0)); } else SelectInput("Enter filename to download", "download", "download"); } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void SD_file_download(String filename) { if (SD_present) { File download = SD.open("/" + filename); if (download) { server.sendHeader("Content-Type", "text/text"); server.sendHeader("Content-Disposition", "attachment; filename=" + filename); server.sendHeader("Connection", "close"); server.streamFile(download, "application/octet-stream"); download.close(); } else ReportFileNotPresent("download"); } else ReportSDNotPresent(); } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void File_Upload() { append_page_header(); webpage += F("<h3>Select File to Upload</h3>"); webpage += F("<FORM action='/fupload' method='post' enctype='multipart/form-data'>"); webpage += F("<input class='buttons' style='width:40%' type='file' name='fupload' id = 'fupload' value=''><br>"); webpage += F("<br><button class='buttons' style='width:10%' type='submit'>Upload File</button><br>"); webpage += F("<a href='/'>[Back]</a><br><br>"); append_page_footer(); server.send(200, "text/html", webpage); } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ File UploadFile; void handleFileUpload() { // upload a new file to the Filing system HTTPUpload& uploadfile = server.upload(); // See https://github.com/esp8266/Arduino/tree/master/libraries/ESP8266WebServer/srcv // For further information on 'status' structure, there are other reasons such as a failed transfer that could be used if (uploadfile.status == UPLOAD_FILE_START) { String filename = uploadfile.filename; if (!filename.startsWith("/")) filename = "/" + filename; Serial.print("Upload File Name: "); Serial.println(filename); SD.remove(filename); // Remove a previous version, otherwise data is appended the file again UploadFile = SD.open(filename, FILE_WRITE); // Open the file for writing in SPIFFS (create it, if doesn't exist) filename = String(); } else if (uploadfile.status == UPLOAD_FILE_WRITE) { if (UploadFile) UploadFile.write(uploadfile.buf, uploadfile.currentSize); // Write the received bytes to the file } else if (uploadfile.status == UPLOAD_FILE_END) { if (UploadFile) // If the file was successfully created { UploadFile.close(); // Close the file again Serial.print("Upload Size: "); Serial.println(uploadfile.totalSize); webpage = ""; append_page_header(); webpage += F("<h3>File was successfully uploaded</h3>"); webpage += F("<h2>Uploaded File Name: "); webpage += uploadfile.filename + "</h2>"; webpage += F("<h2>File Size: "); webpage += file_size(uploadfile.totalSize) + "</h2><br>"; append_page_footer(); server.send(200, "text/html", webpage); } else { ReportCouldNotCreateFile("upload"); } } } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void SendHTML_Header() { server.sendHeader("Cache-Control", "no-cache, no-store, must-revalidate"); server.sendHeader("Pragma", "no-cache"); server.sendHeader("Expires", "-1"); server.setContentLength(CONTENT_LENGTH_UNKNOWN); server.send(200, "text/html", ""); // Empty content inhibits Content-length header so we have to close the socket ourselves. append_page_header(); server.sendContent(webpage); webpage = ""; } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void SendHTML_Content() { server.sendContent(webpage); webpage = ""; } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void SendHTML_Stop() { server.sendContent(""); server.client().stop(); // Stop is needed because no content length was sent } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void SelectInput(String heading1, String command, String arg_calling_name) { SendHTML_Header(); webpage += F("<h3>"); webpage += heading1 + "</h3>"; webpage += F("<FORM action='/"); webpage += command + "' method='post'>"; // Must match the calling argument e.g. '/chart' calls '/chart' after selection but with arguments! webpage += F("<input type='text' name='"); webpage += arg_calling_name; webpage += F("' value=''><br>"); webpage += F("<type='submit' name='"); webpage += arg_calling_name; webpage += F("' value=''><br>"); webpage += F("<a href='/'>[Back]</a>"); append_page_footer(); SendHTML_Content(); SendHTML_Stop(); } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void ReportSDNotPresent() { SendHTML_Header(); webpage += F("<h3>No SD Card present</h3>"); webpage += F("<a href='/'>[Back]</a><br><br>"); append_page_footer(); SendHTML_Content(); SendHTML_Stop(); } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void ReportFileNotPresent(String target) { SendHTML_Header(); webpage += F("<h3>File does not exist</h3>"); webpage += F("<a href='/"); webpage += target + "'>[Back]</a><br><br>"; append_page_footer(); SendHTML_Content(); SendHTML_Stop(); } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void ReportCouldNotCreateFile(String target) { SendHTML_Header(); webpage += F("<h3>Could Not Create Uploaded File (write-protected?)</h3>"); webpage += F("<a href='/"); webpage += target + "'>[Back]</a><br><br>"; append_page_footer(); SendHTML_Content(); SendHTML_Stop(); } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ String file_size(int bytes) { String fsize = ""; if (bytes < 1024) fsize = String(bytes) + " B"; else if (bytes < (1024 * 1024)) fsize = String(bytes / 1024.0, 3) + " KB"; else if (bytes < (1024 * 1024 * 1024)) fsize = String(bytes / 1024.0 / 1024.0, 3) + " MB"; else fsize = String(bytes / 1024.0 / 1024.0 / 1024.0, 3) + " GB"; return fsize; }and this is the page void append_page_header() { webpage = F("<!DOCTYPE html><html>"); webpage += F("<head>"); webpage += F("<title>File Server</title>"); // NOTE: 1em = 16px webpage += F("<meta name='viewport' content='user-scalable=yes,initial-scale=1.0,width=device-width'>"); webpage += F("<style>"); webpage += F("body{max-width:65%;margin:0 auto;font-family:arial;font-size:105%;text-align:center;color:blue;background-color:#F7F2Fd;}"); webpage += F("ul{list-style-type:none;margin:0.1em;padding:0;border-radius:0.375em;overflow:hidden;background-color:#dcade6;font-size:1em;}"); webpage += F("li{float:left;border-radius:0.375em;border-right:0.06em solid #bbb;}last-child {border-right:none;font-size:85%}"); webpage += F("li a{display: block;border-radius:0.375em;padding:0.44em 0.44em;text-decoration:none;font-size:85%}"); webpage += F("li a:hover{background-color:#EAE3EA;border-radius:0.375em;font-size:85%}"); webpage += F("section {font-size:0.88em;}"); webpage += F("h1{color:white;border-radius:0.5em;font-size:1em;padding:0.2em 0.2em;background:#558ED5;}"); webpage += F("h2{color:orange;font-size:1.0em;}"); webpage += F("h3{font-size:0.8em;}"); webpage += F("table{font-family:arial,sans-serif;font-size:0.9em;border-collapse:collapse;width:85%;}"); webpage += F("th,td {border:0.06em solid #dddddd;text-align:left;padding:0.3em;border-bottom:0.06em solid #dddddd;}"); webpage += F("tr:nth-child(odd) {background-color:#eeeeee;}"); webpage += F(".rcorners_n {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:75%;}"); webpage += F(".rcorners_m {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:50%;color:white;font-size:75%;}"); webpage += F(".rcorners_w {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:70%;color:white;font-size:75%;}"); webpage += F(".column{float:left;width:50%;height:45%;}"); webpage += F(".row:after{content:'';display:table;clear:both;}"); webpage += F("*{box-sizing:border-box;}"); webpage += F("footer{background-color:#eedfff; text-align:center;padding:0.3em 0.3em;border-radius:0.375em;font-size:60%;}"); webpage += F("button{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:130%;}"); webpage += F(".buttons {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:80%;}"); webpage += F(".buttonsm{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:9%; color:white;font-size:70%;}"); webpage += F(".buttonm {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:70%;}"); webpage += F(".buttonw {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:40%;color:white;font-size:70%;}"); webpage += F("a{font-size:75%;}"); webpage += F("p{font-size:75%;}"); webpage += F("</style></head><body><h1>File Server "); webpage += String(ServerVersion) + "</h1>"; } //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ void append_page_footer(){ // Saves repeating many lines of code for HTML page footers webpage += F("<ul>"); webpage += F("<li><a href='/'>Home</a></li>"); // Lower Menu bar command entries webpage += F("<li><a href='/download'>Download</a></li>"); webpage += F("<li><a href='/upload'>Upload</a></li>"); webpage += F("</ul>"); webpage += "<footer>©"+String(char(byte(0x40>>1)))+String(char(byte(0x88>>1)))+String(char(byte(0x5c>>1)))+String(char(byte(0x98>>1)))+String(char(byte(0x5c>>1))); webpage += String(char((0x84>>1)))+String(char(byte(0xd2>>1)))+String(char(0xe4>>1))+String(char(0xc8>>1))+String(char(byte(0x40>>1))); webpage += String(char(byte(0x64/2)))+String(char(byte(0x60>>1)))+String(char(byte(0x62>>1)))+String(char(0x70>>1))+"</footer>"; webpage += F("</body></html>"); }
