    Using CardKB (not hat) with M5StickC
    M5 Stick/StickC
    4.9k
      mich
      I'm trying to use CardKB with M5 Stick C through grove port. There is an example in the library (which looks like copy paste from M5Stack with only changed header name), but i couldn't make it work. One of the odd things is that messes with gpio5 which is connected to screen. Any suggestion on how to make CardKb work?
      #include <M5StickC.h>
      #include <Wire.h>
      #define CARDKB_ADDR 0x5F
      void setup()
      Serial.begin(115200);
      Wire.begin();
      pinMode(5, INPUT);
      digitalWrite(5, HIGH);
      M5.Lcd.fillScreen(BLACK);
      M5.Lcd.setRotation(3);
      M5.Lcd.setCursor(1, 10);
      M5.Lcd.setTextColor(YELLOW);
      M5.Lcd.setTextSize(2);
      M5.Lcd.printf("IIC Address: 0x5F\n");
      M5.Lcd.printf(">>");
      void loop()
      Wire.requestFrom(CARDKB_ADDR, 1);
      while(Wire.available())
      char c = Wire.read(); // re ceive a byte as characterif
      if (c != 0)
      M5.Lcd.printf("%c", c);
      Serial.println(c, HEX);
      // M5.Speaker.beep();
      // delay(10);
      • ChrisWRC
        ChrisWR
        #include <Wire.h>
        void setup()
          Wire.begin();
        void loop()
            char c = Wire.read(); // receive a byte as characterif
            if (c != 0)
          // delay(10);
          mich
          Thanks! it works.
