    Simple game sample, frustrating results - M5Flow
    PROJECTS
    5.3k
    • I
      iPodLux
      Hi
      I'm sure many have been through this.
      M5Flow blocks used for programming graphics and commands: testing if the interpreter is enough to assemble mid-fast interfaces.
      Example attached:
      Q any way to pass priority to the buttons' trigger and improve response?
      Kind regards
      https://github.com/ipodjupiter/M5Stack.git
      from m5stack import *
      from m5ui import *
      from uiflow import *
      setScreenColor(0x222222)
      circle0 = M5Circle(92, 65, 15, 0xe21414, 0xFFFFFF)
      rectangle1 = M5Rect(0, 220, 30, 15, 0xFFFFFF, 0x22f470)
      label0 = M5TextBox(30, 113, "Text1", lcd.FONT_Default,0xFFFFFF, rotate=0)
      label1 = M5TextBox(29, 145, "Text2", lcd.FONT_Default,0xFFFFFF, rotate=0)
      label2 = M5TextBox(187, 117, "Text3", lcd.FONT_Default,0xFFFFFF, rotate=0)
      label3 = M5TextBox(182, 155, "Text4", lcd.FONT_Default,0xFFFFFF, rotate=0)
      from numbers import Number
      import random
      import math
      pos = None
      circY = None
      circX = None
      destCircY = None
      destCircX = None
      def buttonA_wasPressed():
      global pos, circY, circX, destCircY, destCircX
      pos = (pos if isinstance(pos, Number) else 0) + -5
      if pos < 0:
      pos = 0
      else:
      pos = pos
      pass
      btnA.wasPressed(buttonA_wasPressed)
      def buttonC_wasPressed():
      pos = (pos if isinstance(pos, Number) else 0) + 5
      if pos >= 320:
      pos = 320
      else:
      pos = pos
      pass
      btnC.wasPressed(buttonC_wasPressed)
      rectangle1.setPosition(150, 220)
      pos = 150
      circY = 0
      circX = 0
      circle0.setPosition(30, 30)
      while True:
      rectangle1.setPosition(x=pos)
      destCircY = random.randint(0, 200)
      destCircX = random.randint(0, 320)
      while math.fabs(circX - destCircX) > 10 or math.fabs(circY - destCircY) > 10:
      if destCircX - circX > 0:
      circX = circX + 5
      else:
      circX = circX - 5
      if destCircY - circY > 0:
      circY = circY + 5
      else:
      circY = circY - 5
      circle0.setPosition(circX, circY)
      wait_ms(5)
      wait_ms(2)
      • I
        iPodLux @iPodLux
        @ipodlux Found it!
        in order to compensate the slow reading of the interrupt I moved the reading in the loop. It less less classy that the external function but now it reacts as it should.
