    Using a API to send out a SMS
    M5 Stick/StickC
    4.3k
    • R
      rbrakus
      After running this code, I get no errors only a blank screen. Could anyone tell what I did wrong at first glance?
      from m5stack import *
      from m5ui import *
      from uiflow import *
      fields = {
      'from': 'PythonElk',
      'to': '+XXXXXXXX',
      'message': 'Test Message To your phone.'
      try:
      req = urequests(
      method='POST',
      url='https://api.46elks.com/a1/SMS',
      headers=fields,
      data={'XXXXXXXXXXXXXXXXXXXXX',' YYYYYYYYYYYYYYYYYYYY'}
      except Exception as e:
      print(e)
      import urequests
      import ujson
      setScreenColor(0x111111)
      auth = (
      'XXXXXXXXXXXXXXXXXXXXXXXX',
      'YYYYYYYYYYYYYYYYYYYYYY'
      fields = {
      'to': '+XXXXXXXX',
      headers = {'Content-Type': 'application/json'}
      try:
      #urequests.request(method='POST', url='https://api.46elks.com/a1/SMS', auth, fields,headers
      post_data = ujson.dumps('XXXXXXXXXXXXXXXXXXXXXXX','YYYYYYYYYYYYYYYYYYYYYYYYYYY')
      request_url = 'https://api.46elks.com/a1/SMS'
      res = requests.post(request_url, headers = {'content-type': 'application/json'}, data = post_data,json=fields)
      print(res)
      req = urequests.request(method='POST', url="import urequests setScreenColor(0x222222) fields = { 'from': 'PythonElk', 'to': '+XXXXXXX', 'message': 'Test Message To your phone.' } try: req = urequests.request( method='POST', url='https://api.46elks.com/a1/SMS', headers=fields, data=('XXXXXXXXXXXXXXXX','YYYYYYYYYYYYYYYYYYYYY') ) except: print(req.status_code)",json={'user':'a'}, headers={})
      print(e)
        I do not see any GUI objects required to show text on the screen. I only see code that runs in the background.
        • R
          rbrakus
          Me and a friend of mine figured out how to do a HTTP post with parameters in micropython. Me used it for sending SMS, but it can be modified to anything else.
          https://forum.m5stack.com/topic/1902/http-post-from-arduino-esp8266-esp32-how-to-send-parameters-x-www-form-urlencoded-using-micropython/3
