UI flow - connexion problem usb port
Hello
I just start with M5stick-C and i have some problem
I have installed m5burner and it works fineI tried Ui flow and impossible to connect to the m5stack-c..
When I connected to the pc on windows 10, it s seen as usb serial port (com3)..
I use this port in ui flow and impossible to connect...Any idea ?
Thanks for you helo
Is the stick set to USB mode?
If its in wifi mode, the com port will still be present, you just won't be able to program it locally.as soon as you switch the stick on, you need to press one of the buttons to go into the setting and change it from wifi to USB mode.
@ajb2k3 Thanks for you message. Indeed, I didn't configure correctly. now is it connected !
I can run a program but it is not possible to download the code in the stick
@bww1340 The download button in the setting menu is not working?
@ajb2k3 ![
i get this error message -
@bww1340 Repost this one in the official updates forum under the 1.5.1 (or which ever version you are struggling with.)
