M5stick power issues when disconnected
My M5stickC was working perfectly, but now (in Bluetooth communication) when I disconnect it from from the PC it turns off. How can I see if there are problems with the battery and how can I solve it? Thank you
@giulio can you describe the problem? Does the stick fail immediately when you disconnect? If not, can you check battery voltage and flow?
