    Reading data from MPU with M5Stick V on MaixPy
    Scheduled Pinned Locked Moved M5Stick V
    3 Posts 2 Posters 7.0k Views 1 Watching
      Alisson Brito
      Hi guys,
      Do you have some example using MPU on a M5Stick V with MaixPY? The examples I found return error when trying to write memory with command: "write_i2c(MPU6886_PWR_MGMT_1, 0x00)". The error message is:
      File "<stdin>", line 44, in <module>
      File "<stdin>", line 41, in write_i2c
      OSError: [Errno 5] EIO
      • m5stackM Offline
        you could find the MPU6886 example in this page:
        https://docs.m5stack.com/#/en/related_documents/M5StickV-Maixpy
          Alisson Brito
          When I try to run the code I have the following message:
          File "<stdin>", line 59, in <module>
          File "<stdin>", line 32, in MPU6866_init
          File "<stdin>", line 28, in write_i2c
          Do you know what it could be?
