Pin Header and Sockets: Part-Numbers
 Hello, does someone know the manufacturers and the part numbers for the sockets and headers? I read that they may be from samtec, but I did not find sockets with a 2.54mm pitch and 2.2mm profile(height) Could someone tell me where to get theme. Thanks a lot. Best Regards, Seppel
 @seppel as far as I am aware they are custom sized.
 if you are talking about the internal bus connector then
 https://m5stack.com/collections/m5-accessory/products/2x15-pin-headers-socket
 Hello, I highly doubt that, all M5Stack likes to do is: 1. Buy overpriced connectors 2. Limit the āopennessā and control the marked of modulesI love the idea and package of the M5Stack, but the connectors are just stupid, require high forces, difficult to find, ⦠. Maybe I will use other very common low-profile types, do it in FreeCAD, and KiCAD so we can get rid of that nonsense connectors for 3rd Party and custom modules. Best Regards, Seppel
 Hello, Does anyone find a solution to this?
 I am ordering a circuit at PCBway but they can't order components at M5stack, and I do not find male header anywhere.It looks like it is a SAMTEC connector (low profile), see picture.
 http://suddendocs.samtec.com/catalog_english/ftsh_smt.pdfBut lead style A is 3.05mm (pin height), mesuring the one I have is 2.5mm.
 Not sure 3mm will fit the femelle (too long)?Thanks
 I ask M5stack support, here is their answer: "The 30-Pin connector we are using is a customized one. The pin height with 3mm is no problem to be compatible."
