    M5StickC - can't find serial port on Mac Mojave
    4 Posts 2 Posters 8.5k Views 2 Watching
      csam
      Hi, I've installed the silabs driver and uninstalled and reinstalled and restarted my computer so many times in between. When I run the system report on mac, it shows up as a USB device, but when I list the devices in command line, or when I try to select the port in arduino, it doesn't show up. Is there a way to fix this issue and to get the port to consistently show up without restarting every time?
      Thank you!
      • m5stackM Offline
        you could try to install a FTDI driver.
        https://www.ftdichip.com/Drivers/VCP.htm
          csam
          Thank you! I tried it out, but it didn't work - the port still isn't showing up as an option to connect to. Are there any other suggestions?
          • m5stackM Offline
            m5stack @csam
            @csam ok..could you try again use this firmware upgrade tool:
            https://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-catalina-can-t-upload-programs-solution
