External library
  • hi everyone I recently updated the m5stack core to v1.5.4. would anyone know how to load an external library?
    because I did it with v1.4.5 adding the import in the boot file, but in the new version it doesn't work
  • which lib are you import? the build-in lib? or another custom lib? make sure the root path have the lib file before you import.
    could provide more detail?
  • it's a library to control a sensor, I had already built my custom blocks that worked with that library, but when I updated everything I was unable to make it go.
    so do I have to import the library into the / flash root?
    and then?
