    Creating an infinite async loop
    4 Posts 2 Posters 9.0k Views 1 Watching
      jhfoo
      Looking to write code that will send data via mqtt perpetually. Learn recently that the publish() method is NOT synchronous, which I augmented by listening to a topic for an ack message before calling the iteration done, and the next iteration publish begins.
      So I tried to close the loop by calling the publish() method within the subscribe() handler, and the app crashed with message 'RuntimeError: maximum recursion depth exceeded'.
      How do people get around this?
        jhfoo @jhfoo
        Am trying using ONE_SHOT timers. Not sure if this is the recommended approach.
        • m5stackM Online
          could you share your code to here. maybe people can help you.
            jhfoo @m5stack
            @m5stack I will share pseudo-codes of the current implementation, which is stable so far:
            CycleTimer = Timer(-1)
            def main():
              # init and connect mqtt client
              doCycle()
            def doCycle():
              global CycleTimer
              # send stuff from mqtt
              # NOTE: do not use machine.lightsleep() as publish() is NOT synchronous
              # lightsleep() will block data from being sent
              CycleTimer.init(period=5000, mode=Timer.ONE_SHOT, callback=doCycle)
            NOTE: this is power-intensive; calling lightsleep() will cause uiflow's mqtt client to crash quickly.
