    How to set data type and intial values.
    UIFlow
    7.4k
    • B
      birdsong
      How can a make blockly keep a data type? this Function doesnt work, because 0.1 rounds down to 0 every time the code is executed. It is for an hour meter, I want to add 0.1 every 6mins.
      This is what blockly automaticaly generates;
      if bTm6min and bRunFan:
          fPvHrs = (fPvHrs if isinstance(fPvHrs, Number) else 0) + 0.1
      When i manually change the code the problem goes away until blockly reverts back to the old code again.
      fPvHrs = fPvHrs + 0.1
      • m5stackM
        the bug seem like from micropython. so , maybe you could use other way to change variable.
        eg:
        替代文字
        • R
          robalstona
          Ewentually add 1 instead 0.1 and the end of your calculations divide a value by 10.
          • B
            birdsong
            Converts to;
              if bRunFan and bRunFan != bRunFanOld:
                fPvHrs = 0.01
                fPvHrs = fPvHrs + 0.01
              bRunFanOld = bRunFan
            Thanks M5stack, this worked.
            I didn't want to divide by 10 because I would have to do that everywhere, slow the execution speed, its a slippery slope. The esp32 has very long divide instruction time compared to addition and multiplication.
