    M5Stack Delete App from App List UIFlow V1.5.4
    UIFlow
    5
    5
    11.0k
    • B
      birdsong
      How do I delete apps from the app list with the UIFlow firmware loaded?
      • lukasmaximusL
        Theres no direct way to do it from the menu, but you can do it with uiflow with this method
        or in micropython:
        import os
        os.remove('apps/nameofappyouwanttodelete.py')
        • J
          JhonnyTank @birdsong
          @birdsong
          m5burner has the erase - option where you can erase the device.
          Than flash the firmware onto it.
          • C
            Chappali
            • Switch to you Python code
              and at the bottom left corner select file manager to delete the apps that you dont want
            • O
              oldfart
              This is a great answer.
              It is not obvious that this functionality exists.
