    5V stops working m5stickc
    8 Posts 4 Posters 14.7k Views 1 Watching
    • O Offline
      OS88
      I have a few M5stickc's that I uploaded the added code, and after uploading it the 5V port stops giving voltage immediatly.
      What could be the issue? I am using sleep mode, BLE, and reading some IO's basically.
      This is the code:
      //#include <M5StickC.h>
      #include <BLEDevice.h>
      #include <BLEServer.h>
      #include <BLEUtils.h>
      #include <BLE2902.h>
      //STATE MACHINE
      #define NONE 0
      #define LEFT_ACTIVE 1
      #define RIGHT_ACTIVE 2
      #define BOTH_ACTIVE 3
      #define TIME_BEFORE_SLEEP 10000
      #define TIME_BEFORE_SEND 2000
      RTC_DATA_ATTR int lastState = NONE;
      //#define BUTTON_PIN_BITMASK 0x4000001 //for pins 0,26
      #define BUTTON_PIN_BITMASK 0x300000000 //for pins 32,33
      int state = BOTH_ACTIVE;
      int leftStatus;
      int rightStatus;
      const int leftSidePin = 32;
      const int rightSidePin = 33;
      const int LED = 10;
      unsigned int pingTime = 0;
      //************END STATE MACHINE
      //BLE****
      BLEServer* pServer = NULL;
      BLECharacteristic* pCharacteristic = NULL;
      bool deviceConnected = false;
      bool firstConnection = false;
      #define SERVICE_UUID "801a272c-a57b-11ea-bb37-0242ac130002"
      #define CHARACTERISTIC_UUID "801a29a2-a57b-11ea-bb37-0242ac130002"
      class MyServerCallbacks: public BLEServerCallbacks {
      void onConnect(BLEServer* pServer) {
      deviceConnected = true;
      firstConnection = true;
      pingTime = millis();
      void onDisconnect(BLEServer* pServer) {
      //END BLE
      void setup()
      setupPins();
      startBLEServer();
      //wakingUp();
      //startSleep();
      void loop()
      refreshStatus();
      if (deviceConnected){
      if (firstConnection) {
      delay(300);
      pCharacteristic->setValue(state);
      pCharacteristic->notify();
      else if (millis() - pingTime > 5000) {
      if ( state == NONE ) {
      delay(300);
      startSleep();
      void startSleep() {
      gpio_hold_en(GPIO_NUM_32);
      gpio_hold_en(GPIO_NUM_33);
      gpio_deep_sleep_hold_en();
      Serial.println("Active high will wake me up");
      esp_sleep_enable_ext1_wakeup(BUTTON_PIN_BITMASK,ESP_EXT1_WAKEUP_ANY_HIGH);
      esp_deep_sleep_start();
      Serial.println("This will never be printed");
      void wakingUp(){
      esp_sleep_wakeup_cause_t wakeup_reason;
      wakeup_reason = esp_sleep_get_wakeup_cause();
      switch(wakeup_reason)
      case ESP_SLEEP_WAKEUP_EXT0 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
      case ESP_SLEEP_WAKEUP_EXT1 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
      case ESP_SLEEP_WAKEUP_TIMER : Serial.println("Wakeup caused by timer"); break;
      case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.println("Wakeup caused by touchpad"); break;
      case ESP_SLEEP_WAKEUP_ULP : Serial.println("Wakeup caused by ULP program"); break;
      default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
      refreshStatus();
      void refreshStatus() {
      readInputs();
      getState();
      reportStatus();
      void reportStatus() {
      if (state == NONE) {
      if (lastState == RIGHT_ACTIVE) {
      Serial.println("closed right side");
      else if (lastState == LEFT_ACTIVE) {
      Serial.println("closed left side");
      else {
      Serial.println("error - shouldn't be here L95");
      else if (state == RIGHT_ACTIVE) {
      Serial.println("Right side active");
      else if (state == LEFT_ACTIVE) {
      Serial.println("Left side active");
      else if (state == BOTH_ACTIVE) {
      Serial.println("Both active");
      prints();
      lastState = state;
      void readInputs() {
      leftStatus = digitalRead(leftSidePin);
      rightStatus = digitalRead(rightSidePin);
      void getState() {
      if (!leftStatus && !rightStatus) {
      state = NONE;
      else if (!leftStatus && rightStatus) {
      state = RIGHT_ACTIVE;
      else if (leftStatus && !rightStatus) {
      state = LEFT_ACTIVE;
      else {
      state = BOTH_ACTIVE; // default
      Serial.printf("You are in state %d\n",state);
      void prints() {
      Serial.printf("State: %d, Last state: %d, Left status: %d, Right status: %d,\n",state,lastState,leftStatus,rightStatus);
      void startBLEServer(){
      BLEDevice::init("BLE");
      pServer = BLEDevice::createServer();
      pServer->setCallbacks(new MyServerCallbacks());
      BLEService *pService = pServer->createService(SERVICE_UUID);
      pCharacteristic = pService->createCharacteristic(
      CHARACTERISTIC_UUID,
      BLECharacteristic::PROPERTY_READ |
      BLECharacteristic::PROPERTY_WRITE |
      BLECharacteristic::PROPERTY_NOTIFY |
      BLECharacteristic::PROPERTY_INDICATE
      pCharacteristic->addDescriptor(new BLE2902());
      pService->start();
      BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
      pAdvertising->addServiceUUID(SERVICE_UUID);
      pAdvertising->setScanResponse(false);
      pAdvertising->setMinPreferred(0x0); // set value to 0x00 to not advertise this parameter
      BLEDevice::startAdvertising();
      Serial.println("Waiting a client connection to notify...");
      void setupPins(){
      //M5.begin();
      Serial.begin(115200);
      prints();
      pinMode(LED,OUTPUT);
      digitalWrite(LED,LOW);
      pinMode(leftSidePin, INPUT_PULLUP);
      pinMode(rightSidePin, INPUT_PULLUP);
      • m5stackM Offline
        you could check your code does have operation for AXP192. usually esp32 sleep don't affect the AXP192 output.
        • O Offline
          OS88
          Thanks for the reply. Is there a way to reset AXP to its initial values?
            Pepsi
            Is it the 5volt at the grove connector. Or the unit side?
            • O Offline
              OS88 @Pepsi
              @pepsi Both sides don't work
                Pepsi
                @os88 said in 5V stops working m5stickc:
                I only had the problem, when i uploaded my code the StickC was on. If i turned it off, i was not able to turn it back on with the power button.
                Just like you i had commented out the m5stack.h code.
                Have you tried it when the code Is not uncommitted?
                  void setupPins(){
                  //M5.begin();
                  prints();
                  Should be at the beginning of the code and uncomment M5Begin.
                  • m5stackM Offline
                    just like him said. don't comment the M5.begin();
