    upload via USB from the desktop-Version of UI-Flow
    UIFlow
    9.5k
    • J
      JhonnyTank
      I would like to use the Desktop Version of UI-Flow.
      But I can't get a connection via USB.
      I have installed the USB-Driver several times.
      M5-Burner does work well.
      The Online-Version of UI-Flow is working pretty well but I would like the m5Stick in my lessons, where we have very limitted access to the WiFi-Settings.
      • m5stackM
        you need setup the device to the USB mode before you connect to the Desktop IDE
        more information you could refer this tutorial:
        https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow
        • J
          JhonnyTank
          Sorry the Tutorial is a little bit missleading.
          I am using Firmware 1.5.4 and I am not able to find any option for usb Mode.
          The USB-Driver is working fine, because m5-Burner is able to flash the device.
          • lukasmaximusL
            Which M5Stack device are you using? each device has a different method of getting into usb mode which you have to set on the device itself first. You can check this video for how to set it for each device https://youtu.be/MTCjKhVKOto?t=302
            • J
              JhonnyTank @lukasmaximus
              @lukasmaximus
              Thank you, that helped
