    M5Stack MultiApp Firmware
    18 Posts 6 Posters 57.0k Views 3 Watching
      Calin @pkourany
      @pkourany 在 M5Stack MultiApp Firmware 中说:
      @Calin, I REALLY like this project. My M5Stack (2018) is not very happy with the bottom and battery so I will most likely keep it powered via USB most of the time. Having multiple tools available via the menu is fantastic. Some data logging to SD apps would be great, including the meter app. It would also be great to have a simple logic analyzer available. Thanks for your great work! I need to setup a VS environment now ;)
      Check out the evolved project : https://github.com/botofancalin/M5Stack_SuperApp_PlatformIO
      That one is made on Visual Studio Code and PlatformIO
      This one contain a web server, Wifi settings, WPS, etc...
      hm... logic analyzer... it can be done...
      what exactly do you need to analyze?
      Any other suggestions ?
      P dasloloD 2 Replies Last reply Reply Quote 1
        pkourany @Calin
        @calin, I have seen code for doing a simple I2C sniffer/decoder and possibly one for OneWire. Those would be really useful next to a simple 4-channel logic analyzer with trigger set, sampling rate and small buffer. Suggestions!!! I'm working on it.
        • dasloloD Offline
          daslolo @Calin
          @calin 在 M5Stack MultiApp Firmware 中说:
          Since oscillo works, you can also graph FFT and from that detect Hz +THD.
          Benefit: detects the quality of the electricity and helps troubleshoot and predict issues.
          I started a project on that, measurements are out of wack, maybe we can work together on it?
          https://github.com/laurentopia/M5-Signal-Multimeter
          alt text
            Calin @daslolo
            @daslolo 在 M5Stack MultiApp Firmware 中说:
            alt text
            sure.. i'm in :)
              Murzik
              Dont work precompiled software. My log file is:
              rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
              flash read err, 1000
              ets_main.c 371
                Calin @Murzik
                @murzik 在 M5Stack MultiApp Firmware 中说:
                ets_main.c 371
                First, compile and write any example from M5Stack library to your m5Stack, using arduino IDE or any any other preffered IDE.
                Then flash the precompiled firmware to address 0x10000
                Check out the flashing instructions jpg
                  Murzik @Calin
                  @calin Complete M5Stack-SAM. This software worked fine. Complete on flashing instructions jpg.
                  Dont worked! Any more ideas?
                    Calin
                    It might be the chip revision i tested the multiapp only on M5 with chip revision 1
                    The MultiApp source code is available on github.
                    Compile the code and upload
                      Calin
                      M5Stack MultiApp Advanced released: http://forum.m5stack.com/topic/194/m5stack-multiapp-advanced-firmware
                      Back to PlatformIO IDE :)
                      • dasloloD Offline
                        daslolo
                        With Web Radio and wifi auto-connection WPS!
                          Meldrak
                          The app seems to be broken. I have tried compiling it as per the instructions on a windows 11 and on a mac. I get the same errors on both. Can anyone please help me? Here is the error code from VS.
                          Compiling .pio/build/esp-wrover-kit/src/Apps/WiFiWps/WpsConnect.cpp.o
                          src/Apps/WiFiWps/WpsConnect.cpp: In function 'void wpsInitConfig(bool)':
                          src/Apps/WiFiWps/WpsConnect.cpp:30:12: error: 'struct esp_wps_config_t' has no member named 'crypto_funcs'
                          config.crypto_funcs = &g_wifi_default_wps_crypto_funcs;
                          src/Apps/WiFiWps/WpsConnect.cpp:30:28: error: 'g_wifi_default_wps_crypto_funcs' was not declared in this scope
                          src/Apps/WiFiWps/WpsConnect.cpp:30:28: note: suggested alternative: 'g_wifi_default_wpa_crypto_funcs'
                          src/Apps/WiFiWps/WpsConnect.cpp: In function 'void Wps_run(bool)':
                          src/Apps/WiFiWps/WpsConnect.cpp:90:27: error: no matching function for call to 'onEvent(void (&)(arduino_event_id_t, system_event_info_t))'
                          WiFi.onEvent(WiFiEvent);
                          In file included from /Users/redacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiSTA.h:28,
                          from /Users/redacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFi.h:32,
                          from lib/M5Stack/M5StackMod.h:30,
                          from src/Apps/WiFiWps/WpsConnect.h:2,
                          from src/Apps/WiFiWps/WpsConnect.cpp:8:
                          /Users/redacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiGeneric.h:159:21: note: candidate: 'wifi_event_id_t WiFiGenericClass::onEvent(WiFiEventCb, arduino_event_id_t)' <near match>
                          wifi_event_id_t onEvent(WiFiEventCb cbEvent, arduino_event_id_t event = ARDUINO_EVENT_MAX);
                          /Users/redacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiGeneric.h:159:21: note: conversion of argument 1 would be ill-formed:
                          src/Apps/WiFiWps/WpsConnect.cpp:90:18: error: invalid conversion from 'void ()(arduino_event_id_t, system_event_info_t)' to 'WiFiEventCb' {aka 'void ()(arduino_event_id_t)'} [-fpermissive]
                          In file included from /Users/readacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiSTA.h:28,
                          from /Users/jredacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFi.h:32,
                          /Users/redacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiGeneric.h:161:21: note: candidate: 'wifi_event_id_t WiFiGenericClass::onEvent(WiFiEventSysCb, arduino_event_id_t)' <near match>
                          wifi_event_id_t onEvent(WiFiEventSysCb cbEvent, arduino_event_id_t event = ARDUINO_EVENT_MAX);
                          /Users/redacted/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiGeneric.h:161:21: note: conversion of argument 1 would be ill-formed:
                          src/Apps/WiFiWps/WpsConnect.cpp:90:18: error: invalid conversion from 'void ()(arduino_event_id_t, system_event_info_t)' to 'WiFiEventSysCb' {aka 'void ()(arduino_event_t*)'} [-fpermissive]
                          *** [.pio/build/esp-wrover-kit/src/Apps/WiFiWps/WpsConnect.cpp.o] Error 1
                          ========================== [FAILED] Took 6.34 seconds ==========================
                          • The terminal process "platformio 'run'" terminated with exit code: 1.
                          • Terminal will be reused by tasks, press any key to close it.
