    Cant run M5Burner in Linux
    9 Posts 4 Posters 20.7k Views 1 Watching
    • X Offline
      xis
      I cant start the new M5Burner on Ubuntu 18.04.4 LTS. I get a JavaScript error:
      GLIBC_2.28 not found
      Please help.
      • lukasmaximusL Offline
        Are you using standalone burner or firmware burner within uiflow desktop ide? I suggest you use the latter, I had no issues flashing devices this way on ubuntu 18
          ajb2k3 @xis
          @xis said in Cant run M5Burner in Linux:
          Please help.
          Have you updated GlibC to 2.28?
          • m5stackM Offline
            thank you feedback. we will fix this problem as soon as possible
            • X Offline
              xis
              Thank you for the help.
              So, using uiflow desktop ide there is another error:
              Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse
              MAC: d8:a0:1d:56:b9:b8
              Uploading stub...
              A fatal error occurred: Timed out waiting for packet header
              Burn Failed
              How can I update GlibC to 2.28?
                Which baud rate did you use? for M5stickC and M5atom you should use baud rate 750000, make sure the correct serial port is selected and that you have erased the device before flashing.
                Edit - also not sure if you already know this but using esp32 devices on linux you need to add the current user to the dialout group in order to access the port that the device is connected to. Open up a terminal and enter these commands
                Sudo usermod -a -G dialout $user
                Sudo chmod a+rw /dev/ttyUSB0
                • X Offline
                  xis
                  Connecting........__.....
                  Detecting chip type...
                  Erase Failed
                  That is using 750000 baud rate.
                  User is on the dialout group.
                  Arduino IDE works. And also the last version of M5Burner used to work.
                  • m5stackM Offline
                    m5stack @xis
                    @xis the software has been updated. you could download a new one, then try it again.
                    • X Offline
                      xis
                      Works great. Thank you so much :)
