šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    [Solved] UnitV unable to find april-tags
    7 Posts 3 Posters 14.9k Views 1 Watching
    • hagueH Offline
      hague
      I can detect april-tags with the StickV, but not with the UnitV AI camera. For the UnitV I use the same code, but without the LCD calls. Here's the code:
      import sensor
      import image
      import math
      print("start script")
      sensor.reset()
      sensor.set_pixformat(sensor.RGB565)
      sensor.set_framesize(sensor.QQVGA) # 160 x 120 pixel
      sensor.run(1)
      sensor.skip_frames(30)
      print("start loop...")
      while True:
          img=sensor.snapshot()
          tags = img.find_apriltags() # defaults to TAG36H11 without ā€œfamiliesā€.
          if len(tags) > 0:
              for tag in img.find_apriltags(): # defaults to TAG36H11 without ā€œfamiliesā€.
                  #img.draw_rectangle(tag.rect(), color = (255, 0, 0))
                  #img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0))
                  degress = 180 * tag.rotation() / math.pi
                  print(tag.id(),degress)
      I have uploaded the latest firmware. What can be the reason that no april-tags are detected?
      • hagueH Offline
        hague
        In addition to the code, here are some screenshots:
        M5StickV with the above code:
        M5StickV
        As you can see, the april tags are detected correctly (output in the serial terminal)
        UnitV with the same code:
        UnitV
        No tags are detected...
        Same firmware, same MaixPy version, same code... But a different behavior...
        • hagueH Offline
          hague
          OK, I found the cause: The image from the camera was mirrored. So the tag could not be detected. I found the error when I tried to detect QR codes:
          UnitV QRcode failure
          Then I added the following line of code to mirror the image:
          sensor.set_vflip(1)
          After that, the QR code was detected correctly:
          UnitV QRcode correctly
          Now, also april tags are working:
          UnitV april tag correctly
            kylebuttress
            Nice one, what firmware are you using for the UnitV?
            hagueH 1 Reply Last reply Reply Quote 0
            • hagueH Offline
              hague @kylebuttress
              @kylebuttress Same as for the M5StickV
              M5StickV_Firmware_v5.1.2.kfpkg
              and
              maixpy_v0.5.0_98_gbd7c7ab_m5stickv.bin
              downloaded here:
              https://dl.sipeed.com/MAIX/MaixPy/release/master
                kylebuttress @hague
                @hague thanks for the info that's a newer version than I have cheers
                  maicongoe
                  @hague good to see! Could you tell me how fast it can run? FPS and at resolution? Thanks!
                  With your input, this post could be even better šŸ’—
