    USB driver for Raspberry Pi
    raspberry piusb driver
    3 Posts 2 Posters 11.7k Views 2 Watching
      FunkyFab
      Hi there,
      I'm trying to have the M5Stack products communicating by USB with my Raspberry PI.
      I've tried using the source package from https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CP210x_VCP_Linux.zip.
      I unzip the file, I have a .tar.gz file, I gaip -d it, got a tar. When doing a tar xvf on it, I have some error messages (tar: Ignoring unknown extended header keyword 'SCHILY.dev' for instance).
      I have only few files, including a Makefile, but when I run the make command, I have :
      make -C /lib/modules/uname -r/build M=/home/pi/Downloads/toto modules
      make[1]: *** /lib/modules/4.19.66-v7+/build: No such file or directory. Stop.
      Makefile:7: recipe for target 'all' failed
      make: *** [all] Error 2
      I've also tried directly connected my M5Stack device, but I have the following lines in my /var/log/messages, and there's not serial port available:
      Jul 28 08:47:56 raspberrypi kernel: [61085.228222] usb 1-1.2: new full-speed USB device number 11 using dwc_otg
      Jul 28 08:47:57 raspberrypi kernel: [61086.098232] usb 1-1.2: new full-speed USB device number 12 using dwc_otg
      Jul 28 08:47:57 raspberrypi kernel: [61086.232479] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 5.00
      Jul 28 08:47:57 raspberrypi kernel: [61086.232503] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      Jul 28 08:47:57 raspberrypi kernel: [61086.232516] usb 1-1.2: Product: M5stack
      Jul 28 08:47:57 raspberrypi kernel: [61086.232528] usb 1-1.2: Manufacturer: Hades2001
      Jul 28 08:47:57 raspberrypi kernel: [61086.232539] usb 1-1.2: SerialNumber: 7152FA2E93
      Jul 28 08:47:57 raspberrypi kernel: [61086.234008] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
      Jul 28 08:47:57 raspberrypi kernel: [61086.234353] usb 1-1.2: Detected FT232BM
      Jul 28 08:47:57 raspberrypi kernel: [61086.235408] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
      Jul 28 08:47:57 raspberrypi mtp-probe: checking bus 1, device 12: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
      Jul 28 08:47:57 raspberrypi mtp-probe: bus: 1, device: 12 was not an MTP device
      Jul 28 08:47:58 raspberrypi kernel: [61086.473162] usb 1-1.2: USB disconnect, device number 12
      Jul 28 08:47:58 raspberrypi kernel: [61086.474080] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
      Jul 28 08:47:58 raspberrypi kernel: [61086.474251] ftdi_sio 1-1.2:1.0: device disconnected
      How can we have the USB communication working with the Raspberry Pi ?
        FunkyFab
        I'll answer myself ;-)
        I copied the /lib/udev/rules.d/69-libmtp.rules to /etc/udev/rules.d, added the line
        ATTR{idVendor}=="0403", ATTR{idProduct}=="6001", GOTO="libmtp_rules_end"
        That prevents the M5 devices to be recognized as MTP devices.
        Then they're recognized as Serial ports, and Arduino IDE can access them.
        So we don't need the driver, just a change in udev configuration.
          ajb2k3 @FunkyFab
          @funkyfab said in USB driver for Raspberry Pi:
          Oh cool, thats for working out how to do this. I can continue my plans of adding an RPI to my project bench to programme the M5Stacks and Sticks.
          Thanks you.
