    Newbie question - cycle functions via one button
    4 Posts 2 Posters 7.7k Views 2 Watching
    • L Offline
      Lukash616
      Hi, I'm making a very simple D&D dice program for the M5stick C via UI Flow blockly.
      I want to be able to use button A to cycle through different dice, as it stands I can only figure out how to do it using wasPressed, DoublePress and longPress.
      What would be the best way to just use single press to cycle functions?
      Here is the beginning of my code, i'm sure it's probably not the most efficient way:
        ardo @Lukash616
        @lukash616
        This maybe could point you in the right direction (subject to improvement ofc.):
        • L Offline
          Lukash616
          Right done some more fiddling and it's almost how i want it. The below works but instead of using wasPressed, longPress and wasDoublePress - i want all states to be selectable by wasPressed.
          Is there a way to do wasPressed Xtimes?
          • L Offline
            Lukash616
            I've figured it out, needed to use lists - this solved it for me https://www.youtube.com/watch?v=4jDVYZSYTo4
